Lowering springs question
Old Apr 5, 2023 | 08:43 AM
projectpanda13's Avatar
projectpanda13
Originally Posted by King300
Hi everyone, I have a 2013 g37x coupe, I recently installed swift lowering springs and noticed that my passenger front had more negative camber than the driver front. It's really off and you can tell by just looking at the wheel that it's not the same at all(I have the alignment sheet attached below). I got recommendations to get front-camber arms, but I need to know the issue first because I believe one side is sitting lower than the other. I measured the bottom of the wheel to the fender and it's off by a 1/4 of an inch on one side. people are telling me it's a bad strut, I just can't seem to wrap my head around the issue. Any recommendations would highly be appreciated.
Are the springs new? There's suppose to be some settling period on new springs. I can also see bad struts causing it to sag also.
Old Apr 5, 2023 | 08:47 AM
King300's Avatar
King300
I actually had H&R springs before the swift springs and I thought maybe I had a bad spring,that was the reason I purchased the swift springs and the same issue still occurred.
Old Apr 5, 2023 | 08:48 AM
projectpanda13
gotcha, i had H&R springs and it was an even drop front to rear for me. Love those springs.
Since the shocks weren't changed between the two springs, I'd point to those.
Can you push down on one side more than the other?
Old Apr 5, 2023 | 08:55 AM
King300's Avatar
King300
Yes the one side that has more camber is way stiffer then the other side. I tried bouncing them both but it’s not the same.
sdhesi
Sep 2, 2022 01:47 AM
Wide boi
Feb 10, 2022 07:21 PM
JoeDirrtyy
Jun 14, 2019 10:23 AM
Himalaya
Jan 16, 2014 08:31 PM
apexi957
May 17, 2011 02:01 PM
