Brake options centric vs power stop, reg vs ipl
Old Sep 30, 2018 | 07:13 PM
Hotsauce55's Avatar
Hotsauce55
Looking for brakes all around and rockauto shows a bunch of standard centric rotor and pad kits + an IPL 355mm front kit option vs stock which I think is 320mm
wondering if this is the way to go or if it will even fit?
Old Sep 30, 2018 | 07:48 PM
slartibartfast's Avatar
slartibartfast
Sigh.
The 355/350 mm discs are for Sport models, of which the IPL is one.
The 320/305(?) mm discs are the standard size.
We really need to sticky the three brake combos.
Old Sep 30, 2018 | 08:54 PM
Hotsauce55's Avatar
Hotsauce55
I clearly and appears correctly noted the existence of the 320mm stock & 355mm sport/ipl options. Question is whether the upgraded will work with the stock calipers and wheels.
appears the calipers are different and not sure 17 inch wheels would accommodate the sport upgrade. If that doesn’t work then I will settle for what I have now. Rockauto makes it a bit confusing as well with 500 different brake options lol
Sticky of the FAQ around brake packages would be good
Old Oct 1, 2018 | 08:57 AM
Baadnewsburr's Avatar
Baadnewsburr
355/350mm rotors only work with the Akebono calipers.
If you have 17" wheels none of the sport/IPL options will fit
Old Oct 1, 2018 | 09:50 AM
Hotsauce55's Avatar
Hotsauce55
perfect!
Old Oct 1, 2018 | 09:59 AM
slartibartfast
Brake sticky added.
jarena2104
Jun 23, 2014 07:57 AM
use2vw
Jul 24, 2013 11:11 AM
G35byteme
Dec 21, 2007 01:30 AM
