Correct Brake Parts
Correct Brake Parts
I am trying to determine the correct brake parts for my 2013 G37XS. I am interested in replacing the rotors with slotted & drilled and a pad with OEM quality ceramic. I am having questions regarding rotor size. Short of removing & measuring them how can i determine diameter & thickness. I do not have Brembo brakes.
Any help is very much appreciated & thank you in advance
320mm/12.6 in front rotors and 307mm/12 in rear rotors for base/journey/AWD G37 sedan models
355mm/350mm respectively for RWD Sport Sedan models
What are you looking for in terms of braking characterstics and use? Decent amount of options out there.
Blank, vented rotors are typically good enough for most applications.
Slotted introduces more wear to your pad with minimal benefit for most street applications.
Drilled introduces an increased likelihood of cracking your rotors (though most reasonable drivers will never cause that to happen)
Mike@Czp
Engine/Intake/Exhaust
1024
May 25, 2018 11:28 AM
b2autodesigns
Wheel & Tires
507
Apr 5, 2018 11:38 AM
b2autodesigns
Brakes/Suspension
573
Mar 29, 2018 11:18 AM
oSnapMillerTime
Dec 5, 2016 02:27 PM
