Need help with hotchkis sways please
Old Dec 20, 2017 | 12:47 PM
Kpmikey808's Avatar
Kpmikey808
Gonna get hotchkis sways for my sedan
I have tein basis coilovers with spc f/r control arms & camber kits
When I buy sway bars - is there anything else I need to add to install like bushings / certain kind of grease for bushings
Mahalos in advanced 🤙
Old Dec 20, 2017 | 01:04 PM
terribleone's Avatar
terribleone
They come with new bushings and with a small amount of grease.
Old Dec 22, 2017 | 08:51 AM
It's not absolutely necessary to upgrade to stronger adjustable sway bar links, but I recommend it.
Synthetic grease lasts longer in the bushings without washing out quickly. They will make noise if not properly greased.
Old Dec 22, 2017 | 03:11 PM
Kpmikey808's Avatar
Kpmikey808
Tire rack hotchis front/rear sways part number
On tire rack they have hotchis front/rear sway bars for 352
When I go to tire racks website site they only show rear hotchis sway that fits
Does anybody know part number
Is the front/back sway bars same as 370z
Old Dec 22, 2017 | 03:12 PM
Kpmikey808's Avatar
Kpmikey808
How does the adjustable bar links help over oem links
Old Dec 22, 2017 | 06:37 PM
slartibartfast's Avatar
slartibartfast
370Z (Z34) = G37 (V36) when it comes to suspension. I have Hotchkis bars and they came from a guy who bought 'em for a Z.
Adjustable links are not necessary unless you lower the car.
Old Dec 22, 2017 | 07:17 PM
Kpmikey808's Avatar
Kpmikey808
Coilover FTG about 26.25
It’s on tein coilovers with spc front/rear arms & camber
Will stock links be ok
Old Dec 22, 2017 | 08:15 PM
slartibartfast
I'm not lowered so haven't directly dealt with the situation. You'll have to read through the suspension and build forums.
Old Dec 23, 2017 | 05:40 PM
Lowering the car changes the suspension geometry. Parts are at angles relative to one anither that they weren't designed to be. Adjustable links can be changed to better line up now that the parts aren't in the same space relative to one another as when the car was stock. They are also more robust and can be greased unlike stock links.
Old Jan 11, 2018 | 02:55 AM
Kpmikey808's Avatar
Kpmikey808
What brand do u recommend
Looks like Moogs are the cheapest rear ending
Links
Should I get front endlinks too? Does Moog make front too
How much will be front & rear end links
Thx u mike 🤙 🤙 🏝 🌊
Old Jan 11, 2018 | 06:08 AM
Surfnazi's Avatar
Surfnazi
You can make your own for less than 30 bucks
Old Jan 11, 2018 | 01:09 PM
I don't recommend making your own end links for the vast majority of people.
I don't know how much the Moog links cost, but I bet Google does! They are not adjustable. If you're not going to pay up to put in adjustable ones, just reuse the stock parts.
SPL and Whiteline and make adjustable ones but they are far more expensive than non adjustable stock end link replacements.
And cheapest should never be a part of any decision involving brake parts, suspension components, or tires.
Old Jan 11, 2018 | 02:57 PM
slartibartfast
Moogs don't fit rear of lowered cars with big bars.
Old Jan 15, 2018 | 10:39 PM
Kpmikey808's Avatar
Kpmikey808
Was reading theu the old threads
Majority of peeps put rear hotchkis sway bar to medium setting?
Old Jan 15, 2018 | 10:50 PM
slartibartfast
Start soft and get used to it. If you want more oversteer, bump it to medium.
