Rear sway bar install
Coupe, Sedan? I think Coupe guys were able to slide it out pretty easily. When I did my sedan though, it was easier to drop the muffler section to slide the new RSB in. Also gives you a bit more room to maneuver.
Coupe owner here: no need to remove exhaust. No need to remove wheels.
I installed it with my car up on ramps. Kind of tricky at points, but very doable. Think of it as a puzzle to solve.
From what I remember, it would be doable with a wheel(s) off. While looking up at it I decided to just lower the exhaust. But mine has flex joints in front of the exhaust cross member thing... so dropped that, unhooked hangers and just swung the plumbing out of the way. From there, straight forward removal and reinstall.
Good luck and post up your results
emyrl
Apr 8, 2018 12:02 PM
ClassyPump
Nov 2, 2017 07:46 PM
mjnoles1
Dec 18, 2015 10:19 PM
Genseven
Aug 11, 2010 05:30 PM
