Swaybar fitment- coupes and sedan same parts?
Old Oct 24, 2017 | 12:43 AM
Luky's Avatar
Luky
I am looking for a set of swaybars for my 2011 G37S sedan and am considering the hotchkis set up. However in looking for the correct part number to order, it seems the same sways are for both the 2dr coupes and the 4dr sedan (hotchkis #22441). Is this correct.?
Old Oct 24, 2017 | 12:47 PM
PNW_IPL's Avatar
PNW_IPL
Same same.
Differences is in diameters from sedan coupe X and S and IPL.
Old Oct 24, 2017 | 02:44 PM
Luky's Avatar
Luky
Ok, so with aftermarket sway bars they can be bolted onto any model G37? It is just the "amount" of stiffness change from stock will vary depending on which specific model you start with (and the stock sway bars coming off).
Is there a market for the "stock" sport sway bars coming off a sport sedan? Should I try to sell them in the classifieds or just toss them? Last question, what is IPL? Was this only a coupe model? I get base, x (AWD), journey (mid level) and sport models. Even saw a G37X-S model. How do I recognize an IPL?
Old Oct 24, 2017 | 02:46 PM
PNW_IPL's Avatar
PNW_IPL
IPL came in coupe only and convertible.
Sways all bolt up same. No market for oem bars unless coupe sport or IPL rear for lesser models to reduce body roll rear. Most fronts same diam.
Old Oct 24, 2017 | 02:51 PM
Luky's Avatar
Luky
Never mind about the IPL questions. I looked it up.
- Thanks anyway.
(Damn! You posted while I was reading and typing.)
Old Oct 24, 2017 | 04:05 PM
slartibartfast's Avatar
slartibartfast
Owners of AWD models might buy your S rear bar. No one seems to want the front bar.
Old Oct 24, 2017 | 04:52 PM
Victory's Avatar
Victory
someone knowledgeable really needs to write a sway-bar guide. I'm clear on the aftermarket stuff, but not clear on which models of G's and Z's have larger factory sway bars and how many varieties of factory swaybar there are. I can find junkyard swaybars for super cheap, but i don't know what fits and what is an improvement.
Old Oct 24, 2017 | 07:11 PM
slartibartfast
AWD has thickest front and thinnest rear bar.
S, both sedan and coupe, have thickest rear bar. Same as Nismo bar on the Z34. Front bar falls between AWD and standard Journey.
Standard Journey has intermediate sized bars.
All these bars are hollow.
Any bar that fits a G also fits the Z. Many vendors don't list Infiniti parts but do carry Nissan, so you have options.
Old Oct 25, 2017 | 09:27 AM
Victory's Avatar
Victory
S, both sedan and coupe, have thickest rear bar. Same as Nismo bar on the Z34. Front bar ***** between AWD and standard Journey.
What about the standard 370z?
Old Oct 25, 2017 | 10:14 AM
hozilla's Avatar
hozilla
I wouldn't exactly call it a guide, but there's a lot of useful information regarding sway bars in this thread - https://www.myg37.com/forums/g37-sed...r-upgrade.html
Old Oct 25, 2017 | 11:48 AM
Victory's Avatar
Victory
per that thread it seems all RWD rear swaybars are the same, S or otherwise. Is this correct? Can i just snag any 370z junkyard swaybar for $50 and call it a day?
Old Oct 25, 2017 | 03:21 PM
hozilla's Avatar
hozilla
If by same, you mean interchangeable, then yes they are.
Quoting Ryne in that particular thread...
"Yes you can. All G37 models (sedan, coupe, RWD, AWD, sport, nonsport) are interchangeable in the rear. There is a widespread controversy about which bar is the most stiff. The consensus though, is that the AWD bar is pathetic and the RWD bars, both sport and nonsport, are much more substantial. Any difference between the RWD sport and nonsport bar, if one even exists, is minute. Also, note that the AWD bar in the front is significantly larger than the RWD, sport or not."
Maybe? I know user RMB5190 has a RSB from a Nismo Z on his G. I personally would double check with the compatibility between model years.
Old Oct 25, 2017 | 04:34 PM
slartibartfast
Any Z34 or V36 rear bar will swap between the chassis.
Old Oct 25, 2017 | 07:47 PM
PNW_IPL's Avatar
PNW_IPL
IPL has the stiffest rear bar. Some 370z guys even upgrade to it over oem nismo rear bar.
Old Oct 25, 2017 | 11:52 PM
slartibartfast
Do you have the thickness of the IPL bar?
