Rotors and Pads. Once And For All End the Madness!
There are so many random posts about Rotors and brake Pads, that I think it's time to settle the debate once and for all in one easy thread for anyone to use in the future...
Stupid me, after trying to solve a sound and then later also a wear issue, I didn't have the mind to measure the dang pads when I had them out, twice! I figured instead of pulling the wheels off and pads out all over again, I'd check on here, but having no luck! So here goes...
Can anyone finally please post accurate rotor & pad specs for the different years and G37 models? Hopefully specifically for a 2013 G37xS Coupe? Please??? Thank you in advance!!!
You have the big Akebono brakes which is 355mm front, 350mm rear rotors. If you're having a problem ordering it's the same as the G37 RWD Coupe or Sedan w/ sport package.
Thanks BTW! I finally got around to it and got them. Now just waiting for my new tires to show up!
hey im just wondering if u kno the diameter of the front rotor and rear thanks?
