Order of spring lowness?
Old Jun 6, 2017 | 10:00 AM
HotSawce's Avatar
HotSawce
I remember reading this somewhere but forget. More specifically I want to know which spring will be second to the Tein S tech in terms of lowness. I planned to get those but was worried about too much scraping. Now that I'm adding a splitter which will extend out 2-3 inches, it will only make it worse, and probably too much. So I figured I should get the next lowest ones.
Old Jun 6, 2017 | 11:16 AM
guy from norcal's Avatar
guy from norcal
That would probably be the eibachs.
Old Jun 6, 2017 | 12:46 PM
HotSawce's Avatar
HotSawce
You sure it's not the H-Tech? Apparently those are 1.5" Front 1.1" rear compared to the eibach 1.2" front 0.9" rear.
Old Jun 6, 2017 | 02:08 PM
Mild to wild~Tanabe, H-Tech, Swift, Eibach, S-Tech, H&Rs.
TBH, why not just get Tein Basis Z coilovers and get just the height you want, only a couple hundred more than springs.
Old Jun 6, 2017 | 02:44 PM
HotSawce's Avatar
HotSawce
I don't understand.. are the specs listed on websites for the H techs and eibachs not correct?
Old Jun 6, 2017 | 04:15 PM
I'd try and do an image search and see if you can get some good visuals. I've found what's listed on spec sheets doesn't always accurately represent how low they drop, H&R is a prime example, they drop a lot more than what they list. The list I provided starts w/ mild and ends w/ deepest drop.
Old Jun 6, 2017 | 08:20 PM
saywat?'s Avatar
saywat?
i can tell u the tanabes rear drop is listed incorrectly nor is it logical
Old Jun 11, 2017 | 05:22 PM
HotSawce's Avatar
HotSawce
Does anyone know if there's a reason why the eibachs are wildly more popular than the H techs? In fact, it seems as though the H-techs are the most uncommon spring for the car.. Is there anything I should be concerned about with them?
Old Jun 11, 2017 | 06:37 PM
saywat?'s Avatar
saywat?
Could be bc it's too low for some people or bc they're using the same springs from the g35 so people don't like that idea. U still haven't decided on wat suspension ur going with? I thought u picked up something already
Old Jun 11, 2017 | 09:33 PM
H techs are a linear spring, Eibach are progressive, here's a good link to explain what's what~
Linear Rate Springs vs Progressive Rate Springs: What's best for me?
Old Jun 11, 2017 | 10:03 PM
saywat?'s Avatar
saywat?
Naw man teins are progressive
Old Jun 11, 2017 | 10:15 PM
I know Tein lists them as progressive but the windings are pretty linear vs. typical progressive springs, here's an H-Tech for the G37
Infiniti G37 TEIN H. Tech Springs
And an Eibach, pretty dramatic difference in the windings~
Old Jun 11, 2017 | 10:26 PM
saywat?'s Avatar
saywat?
Teins site says it's progressive so that's wat I'm going by.
Old Jun 11, 2017 | 10:51 PM
HotSawce's Avatar
HotSawce
Yeah the H techs definitely look linear. And I take it that linear isnt as good for daily, non track driving as progressive?
Old Jun 11, 2017 | 11:15 PM
Yeah, they are listed that way and maybe some of their applications have a more progressive spring pack. The S Techs are definitely progressive for the G37
Infiniti G37 Coupe Tein S Tech Springs
