Replacing rear brakes
Old Jun 3, 2017 | 03:11 PM
Rsmith95's Avatar
Rsmith95
Hi guys this is my first time posting here. So I have a g37 base sedan and I need to replace the rear brakes. I was hoping to get a solid rear brake set that is under $100 and doesn't require new rotors. Any recommendations would be awesome. Thanks!
Old Jun 3, 2017 | 03:27 PM
Have your rotor thickness checked, if they're still ok then a good set of pads is all you need, although at this point a full brake fluid flush would be a good plan. Stoptech has a new street pad (this isn't the same as their previous street pad) it is similar to oem w/ improved bite but not the excess dusting like the previous version.
Here's the part# for the rear base sedan brakes
Amazon Amazon
Might want to do the front too w/ a matching pad set, would be a better plan IMO.
Old Jun 5, 2017 | 11:35 AM
nfsG37's Avatar
nfsG37
AutoAnything has Centric Premium rotors and PosiQuiet ceramic pads (both are OEM equivalent or better) for under $110. I plan on ordering a set within the next few weeks, as my pads are getting low. Like someone else said, you may want to check your rotor thickness/quality to see if those are needed too.
Old Jun 7, 2017 | 02:34 AM
clovissimo's Avatar
clovissimo
I payed 330 at infiniti for new rear brakes and resurfaced rotors. Not bad and I trust the dealer over anywhere else. I'd do it myself but hard to find time with 60 hr weeks.
Old Jun 7, 2017 | 07:51 AM
telcoman's Avatar
telcoman
Agreed!
Here is a photo of my local dealer prices on brakes.
Even if I had the time I'd rather trust the dealer since your life and the life of others depends on brakes and tires.
Always nice to drive a new loaner vehicle while the dealer does the work.
FWIW I'm still on my original factory OEM pads and rotors at almost 88k miles
Telcoman
Old Jun 7, 2017 | 07:57 AM
clovissimo's Avatar
clovissimo
Oops. 330 was with the oil change as well. But yeah, Some things like brakes and trans fluid service better left to the dealer or a mechanic that knows your car.
