Need to Know Suspension Part Numbers
Old Dec 20, 2016 | 06:42 AM
Jbeck's Avatar
Jbeck
The other day I hit a curb pretty good and jacked up my 2011 X Sedan. After inspection it looks like I've snapped my "rear lower camber arm" or "rear lower control arm" I've seen it called by both names. I can not, however, find an OEM replacement. All I can find is aftermarket adjustable camber versions.
Also, here is the front on the same side, which was also thrown out of alignment. Does that control arm look crooked/bent or is it just me?
Old Dec 20, 2016 | 08:57 AM
Click on Rear Suspension, then Suspension components, should be part #8
https://discountinfinitiparts.com/pa...siteid=215255#
Old Dec 20, 2016 | 09:03 AM
LateApex's Avatar
LateApex
Googling "OEM Infiniti Parts" will yield a number of sites where you can look up, and order if you want, the OE parts, usually at a discount vs your local dealer, who could also look them up for you. From the first couple hits I get:
https://www.discountinfinitiparts.co...siteid=215255#
https://orderinfinitiparts.com/parts...iagram=3846475
REAR SUSPENSION for 2011 Infiniti G37
