Just lowered g37 sedan on stech
Old Oct 24, 2016 | 08:27 PM
Elig37sedan's Avatar
Elig37sedan
Just lowered my G37 sedan on stech springs and want to go on 19's make it look square not cambered (if possible) anyone knkw what specs i need to get on wheels and tires?
Old Oct 24, 2016 | 08:47 PM
Welcome to the site I'm moving this to the suspension folder. On deep drop springs like S Techs you'll need Camber kits, at the very minimum you'll need rear camber arms, rear toe bolts. For reasonable tread wear you should also get the front aftermarket upper control arms. SPC is the most common brand and cost about $160 for the back and $350 for the front, if you don't get them you will be spending that much in frequent tire purchases. As far as wheels, way too many choices out there, is there a style and budget you have in mind?
Old Oct 24, 2016 | 08:57 PM
Elig37sedan
Thanks for that info i will be looking for the camber kits i guess... well i been looking into the VMR V710 rims 19's buget is no more then 1k
Old Oct 24, 2016 | 09:25 PM
Check our classifieds on the site for wheel sets and camber kits, sometimes you can find some nice deals. On site vendors B2 Autodesigns & TH Motorsports are good sources for many parts. The VMRs are a decent choice for a cast wheel, the only size that will work without stretching tires or running extra camber would be the 19x8.5 +35. Sometimes Venom GT9 finds some crazy deals on lighter weight high quality wheels on the last pages of this thread https://www.myg37.com/forums/private...ation-etc.html
