Rear Camber?
Old May 31, 2016 | 12:48 PM
grocerylist's Avatar
grocerylist
Rear Camber?
Hi I'll be lowering my G37 sedan (not slammed, just removing some wheel gap) on Tein Basis coilovers and going with the 370Z Sport Rays. I ordered the SPL FUCA & SPL rear camber arms... Would I also need a SPC rear eccentric toe bolts or SPL PRO Eccentric Lockout Kit? From what I can tell the Toe arms are only needed for true style coilovers?
Wanted to make sure I had everything I needed to get it aligned properly. I'll likely be doing the coilover installation but I was going to let a performance alignment shop install the FUCAs and rear camber arms.
Thanks!
Old May 31, 2016 | 01:23 PM
VenomGT9's Avatar
VenomGT9
The toe bolts would be a good thing to add but I don't think your toe will be out of spec
Old May 31, 2016 | 06:01 PM
saywat?'s Avatar
saywat?
when i did my g35 i installed just the camber arms hoping i could get away with not installing the toe bolts. that was not the case. they couldnt get the toe back in spec after getting the camber to spec. so i had to install the bolts and take it back lol
Old May 31, 2016 | 07:29 PM
grocerylist
Thanks, I just ordered the spc toe bolts since they're only $30.
Old Jun 1, 2016 | 08:53 AM
The 2nd link in this thread shows a good install
https://www.myg37.com/forums/brakes-...-template.html
rsingerG37
Aug 15, 2019 01:05 PM
G37sGraphite
Feb 23, 2017 07:37 PM
Dough1397
Mar 29, 2016 10:41 PM
xnick101
Mar 27, 2016 10:12 PM
2013G
Mar 21, 2016 12:44 PM
