Help Air Lift suspension system tank leak air. Anyone face similiar problem?
Old May 16, 2016 | 03:49 PM
*ICE*'s Avatar
*ICE*
hey guys.
recently my Air Lift tank was unable to hold a steady pressure and has been leaking air. After 2 days of not driving, it dropped to 0 PSI. the pressures in 4 corners are still perfectly fine and the car is driveable with no problem.
I've been spraying soapy water around the tank's fitting area, connectors trying to find a leak but no success.
I've contacted Fender Defender (great shop in SoCal who installed my system) and they said there are 5 other people have been experiencing the same problem, all with Air Lift system, and they suspected that the Manifold is the culprit of the problem.
I will try to spray more soapy water on the manifold tonight and report back my finding.
Old May 19, 2016 | 12:39 PM
R1 Dan G37's Avatar
R1 Dan G37
Sorry I can't help but I would be interested in if you have heard anything since or solved the issue, I was actually looking to get the Airlift 3H management kit in the near future and never heard anything bad about them
Old May 24, 2016 | 01:39 AM
*ICE*'s Avatar
*ICE*
I found the problem!
The leak was from my SMC check valve. See the video below.
You can hear the air leak when I move the leader hose back and forth. The SMC valve was dirty when I removed it. The dirt block it from closing all the way, causing the leak. I cleaned it and put in a new valve and save that one for back up.
All are good now!
Gfactor_416
MODDING 411
Nov 6, 2019 08:49 PM
xstarpro
Apr 1, 2016 01:05 PM
armino41
Mar 30, 2016 01:25 PM
OfficialG
Mar 28, 2016 03:23 AM
orleansg37
Mar 27, 2016 04:43 PM
