For new Sway bars New endlinks required?
Old Jan 22, 2016 | 02:49 PM
symphx's Avatar
symphx
Well the title says it all: I have a g37 2013 journey, sport tires
Im convinced Eibach antiroll/sway kit front and back would be nice; One installer suggested I should get new 'endlinks' if new sway bars.
This adds expense I want prepared for, endless new research , and more worry of added noise, squeeks, and squeels over bumps turns etc.
Opinions? do I need, how dangerous if I dont? Is this a minor or MAJOR issue? Thanks!
Old Jan 22, 2016 | 03:39 PM
Lego_Maniac's Avatar
Lego_Maniac
I personally dont think you need new endlinks.
I have 25k and 4 years on my Eibach swaybars + OE endlinks.
Old Jan 22, 2016 | 05:19 PM
No, not necessary but recommended. OEM ones are not that expensive. Aftermarket ones are pricier. The benefit to changing them now is only doing the remove and replace labor once.
Old Jan 22, 2016 | 07:07 PM
symphx's Avatar
symphx
Im already worried about creaks and sounds from adding the sway bars, Im worried some people say these can be noisy; any inexpensive but better than oem recommendations?
Old Jan 22, 2016 | 08:14 PM
Sway bars aren't noisy at all The only noise you'll get is when the grease dries out of the bushings about every 1 to 2 years. Lubricate them and they're all good again. Sways will keep the wheels more planted to the road during cornering, reducing body roll. A side effect is that any irregularity like a bump or dip that affects one side will now affect both sides more than before.
Cheap and good don't go together with car parts. You want cheap parts or good parts? Pick one. Aftermarket end links are a lot more expensive than OEM ones. A lot.
Infiniti - 07-08 G35 Sedan, 08+ G37 - SPLParts
OEM front endlinks are like $50. If that is stretching your budget, I don't know what to tell you. You need to save up more money I guess.
Old Jan 23, 2016 | 09:50 AM
symphx's Avatar
symphx
How do you relubricate? I would have to bring mine in to a shop which would be a pain. I assume you can't just squirt in some grease with everything tightened down.
Old Jan 23, 2016 | 10:12 AM
Hotchkis sways have grease zerks so that you can lube them without removing anything. Others require that you remove the bushing brackets and bushings and grease the inside and replace them.
Old Jan 23, 2016 | 10:13 AM
Lego_Maniac
The end links dont need lube, its the swaybar bushings that bolt to the car with a U shaped bracket that can squeak. I've relubed the rears once and I was able to squeeze under the car without jacking it up. If you're a big guy, you would probably need to jack up the rear.
Old Jan 23, 2016 | 01:10 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Conditions driven in greatly determine if/when you need to relube the bushings. Mine have been on for nearly 4 years and ~18K miles. Haven't touched them yet, no noises either. Car is rarely driven in the elements.
Old Jan 25, 2016 | 06:41 PM
bri's Avatar
bri
In some cars like my old Subaru the benefit is that the stock end links are hard plastic and the solid end link enables the full benefit of the sway bar. I believe the G stock end link is already solid so the only advantage is some adjustability, which I have not yet heard is really necessary.
Old Jan 25, 2016 | 08:24 PM
Adjustability is needed if your car is lowered a lot. And the aftermarket links are much stronger than OEM. I broke the OEM ones on both sides in the rear and I'm not very low. The aftermarket sways are much stiffer than the stock ones.
booster
Dec 30, 2015 10:51 AM
Ayeetyy
Dec 19, 2015 10:04 AM
maxx
Dec 10, 2015 06:50 PM
JG_G37
Dec 9, 2015 02:13 PM
claudiohv
Dec 7, 2015 01:19 PM
