Torn between OEM pads and aftermarket pads?
Old Jul 8, 2015 | 05:32 PM
tomro99's Avatar
tomro99
So I need to swap out my pads as they're pretty much at the end of their life cycle. I have an incredible amount of brake squeal at the moment (don't know if its due to the pads being toast or from the quality of the pads) but nonetheless, I need some input on possible options please. I searched around and found some info but not enough to be able to narrow it down to one pad brand. I was told by a reputable shop by me that OEM pads tend to cause the squeal and I was told by another reputable shop that OEM pads tend to be the quietest. So I'm not sure what to believe? I have a G37S and tend to drive/brake pretty hard from time to time although I don't need extreme performance pads for the track so with that being said, suggestions with what I should go with? What are your guys' experience?
Project Mu?
EBC?
Stoptech?
Akebono?
Centric Posi-Quiet?
OE?
Thanks in advance !
Old Jul 8, 2015 | 05:38 PM
AroundTheG37's Avatar
AroundTheG37
If you don't care about top performance then OEM are the way to go.
Old Jul 8, 2015 | 07:50 PM
tomro99's Avatar
tomro99
Yeah im not looking for a pad like Endless. Maybe something in the middle though between OEM and extreme performance?
Old Jul 8, 2015 | 11:34 PM
tomro99's Avatar
tomro99
Anyone else?
Old Jul 8, 2015 | 11:52 PM
I like the Stoptech Street Pads, have nice bite but dust more than OEM. I've heard the Centric PosiQuiet Ceramics are decent for low dust and similar to OEM braking.
Old Jul 9, 2015 | 12:17 AM
tomro99's Avatar
tomro99
Thanks for that! I have black wheels so I dont think brake dust should be too much of a problem.
Old Jul 9, 2015 | 12:18 AM
JSolo's Avatar
JSolo
Just say no!!!!!
At the rate I'm going it'll be a few years before I needs pads. Stoptech is on my list.
Old Jul 9, 2015 | 12:24 AM
tomro99's Avatar
tomro99
What do you have now?
Old Jul 9, 2015 | 12:27 AM
tomro99's Avatar
tomro99
Also, the stoptechs arent ceramic right?
Old Jul 9, 2015 | 12:28 AM
JSolo's Avatar
JSolo
Just say no!!!!!
^^I have what ever the car came with. It's actually pretty decent for oem. I would like a bit more initial bite though.
http://www.stoptech.com/products/brake-pads
#309
Old Jul 9, 2015 | 05:04 PM
tomro99's Avatar
tomro99
Thanks for that. I may get some new rotors as well. With that being said, what are some rotor + pad options I could go with?
Old Jul 9, 2015 | 06:50 PM
PongSanity's Avatar
PongSanity
Just swapped out for EBC ... they doing the job for me.
Old Jul 9, 2015 | 07:08 PM
OP, just be sure whatever pad you end up with be sure to bed them in properly. Some of the OEM type pads aren't as critical in that regard but the performance oriented pads require an intense bed-in. You won't get proper bite/performance without bedding in the pads as per the manufacturers procedure(s).
Old Jul 9, 2015 | 09:33 PM
tomro99's Avatar
tomro99
Noted! Thanks for that.
Old Jul 9, 2015 | 09:53 PM
Randy Johnson's Avatar
Randy Johnson
I went with brake motive slotted drilled and ceramic pads on my G37S. They stop nice and don't dust too bad.
