Srt8 calipers on G37 Coupe
Old Jun 25, 2015 | 05:23 PM
Carfanatic's Avatar
Carfanatic
Hi everyone is it possible to put SRT8 brembo calipers on my 09 g37 coupe what additional things would I need to make this even close to happening ?
Old Jun 25, 2015 | 05:30 PM
Sure it's possible w/ enough $$. First you'd need to be sure you can get rotors in the proper thickness that has the 5x114.3 bolt pattern. You'd then have to custom build a bracket to mount the caliper centered on the rotor w/ the proper spacing to get full pad coverage (but nothing more).
Unless you just stumbled upon some SRT Brembos for a bargain there's much easier ways to get the BBK. AFAIK the Hyundai Genesis & Camaro Brembos are an easier fit for OEM Infiniti rotors. The Wilwood bolt on BBK is an awesome 6pot/4 pot setup that I'd get before trying to retrofit the other Brembos
Wilwood High-Performance Disc Brakes - 2009 Infiniti G37 4 Door, Except Brembo Brakes
Old Jun 25, 2015 | 05:59 PM
Carfanatic's Avatar
Carfanatic
Your serious, genesis breaks are an easier fit for our cars ?
I'm just annoyed lately I'd just like a BBK on my car but haven't been able to find the proper items like lines and mainly calipers .....
Has anyone done a BBK on an AWD coupe ?
Old Jun 25, 2015 | 06:34 PM
HoldmyMouse's Avatar
HoldmyMouse
If you have trouble sourcing parts then why not get oem bolt on Akebono from the vendors?? They include evening you need to make it work. And yes Akebono bbk can be installed on all awd rwd coups and sedans.
Old Jun 25, 2015 | 08:56 PM
TheLocNar's Avatar
TheLocNar
Just get the OEM kit. Trying to put Dodge brakes on an Infiniti is a waste of time.
https://www.myg37.com/forums/brakes-...the-cheap.html
Old Jun 25, 2015 | 09:24 PM
-SnowMan-'s Avatar
-SnowMan-
+1 on the OEM Sport brakes. 4 pots up front and 2 pots in the back with 14 inch rotors is a pretty decently good brake kit. They feel great.
Old Jun 25, 2015 | 09:58 PM
G37xhibeet's Avatar
G37xhibeet
Old Jun 25, 2015 | 10:30 PM
Carfanatic's Avatar
Carfanatic
Guys I know blwnet posted a template to see if my rims will clear the BBK but I have no idea how to tell or use that template
I have CV1's Vossen
Old Jun 25, 2015 | 10:42 PM
AroundTheG37's Avatar
AroundTheG37
Way not just get oem akebonos unless you have those calipers laying around (would still probably go with OEM)?
Old Jun 26, 2015 | 12:46 AM
Genesis Brembos are easier than SRT Brembos because the Genesis has the same bolt pattern as our Gs (5x114.3). If you want a Akebono BBK just check this thread, you can get a new setup for about $1200 to your door.
As far as the template, just print it out (making sure to get the proper 1" scale) tape it to a cardboard backer and fit inside your current wheel, if you have any contact when rotating around the rim you'll need spacing (or a new wheel) to properly clear. FWIW SRT Brembos have clearance just as bad or worse than Akebonos. That Wilwood kit has better clearance since it's a longer/narrower 6 pot.
KJA8686
Mar 15, 2021 01:27 AM
BANNISTER
Dec 10, 2015 04:14 PM
Slateg37
Sep 16, 2015 05:52 PM
meme405
Aug 19, 2015 07:45 PM
connoisseurr
Aug 16, 2015 04:26 PM
