Lowering advice
Old Apr 15, 2015 | 08:12 PM
Matt813's Avatar
Matt813
Lowering advice
How far can I lower my 2011 sedan with 20x10 275-30-20 and 20x9 245-35-20 before I rub or have to modify the fenders?
Old Apr 15, 2015 | 09:15 PM
HoldmyMouse's Avatar
HoldmyMouse
You should also mention the offsets of the wheels and suspension mods.
Old Apr 15, 2015 | 11:07 PM
Matt813's Avatar
Matt813
35 front 40 rear, I want to just get spring
Old Apr 16, 2015 | 12:36 AM
You can drop it w/ no issues using those wheels/offsets w/ those 245/275 tires. Depending on what springs you go with you'll probably also need at least a rear camber/toe kit.
If you were to go w/ a deep drop spring such as a Tein S Tech or H&R you may get some rubbing of the rear fender liner but that should be it.
Old Apr 16, 2015 | 07:04 PM
Matt813's Avatar
Matt813
I was just wanting the eibach pro 1.5 1.2 drop
Old Apr 16, 2015 | 11:22 PM
You'll be fine but I would recommend at least the rear camber/toe kit.
PearlPereZ
Jun 21, 2016 06:35 PM
cconklin2
Jan 9, 2016 07:21 PM
phamous
Picture Share G Coupe
Sep 30, 2015 02:15 PM
m3clubracer
Sep 20, 2015 09:20 PM
jfisher
Sep 9, 2015 04:17 PM
