Race Pad Bedding
Old Feb 6, 2015 | 04:30 PM
mbar's Avatar
mbar
Race Pad Bedding
Hi everybody,
I just got a new set of EBC Bluestuff. I'm planing to switch my Stoptech pads to the Bluestuff before my next track day.
My question: if I'm planing to switch pads back and forth (keeping the same rottors) do I need to go thru bedding every time?
Thanks
Old Feb 6, 2015 | 05:20 PM
Yes you should bed in each set of different pads you use each time. And be sure flush your brake fluid after each track day.
However, what you might want to seriously consider is getting a second set of rotors to use as well when you track. Bed once and you're good as long as you keep using the same track pads with them. Not very expensive. Not too much work to change out. Well worth is IMO.
Have fun.
xx7sephiroth7xx
Oct 15, 2015 01:44 AM
Kojack
Oct 9, 2015 05:53 PM
EnYcee-G
Oct 4, 2015 09:27 PM
