Brake light while WOT
Old Nov 17, 2014 | 10:38 AM
booster's Avatar
booster
I've noticed that most of the time during moderate to hard acceleration, the brake light comes on on the dash. If it says on for a while the traction control turns off.
I know it's not the emergency brake pedal sensor, since if I step on it while driving I get the warning to disengage it right away.
Any ideas?
The car is a 2010 G37 auto, journey.
Old Nov 17, 2014 | 10:51 AM
CRiME's Avatar
CRiME
Check your brakes, you most likely need new pads. As the pads wear, fluid level drops. Hard acceleration causes the fluid to shift in the reservoir, temporarily triggering the light.
Old Nov 17, 2014 | 11:01 AM
ttv36's Avatar
ttv36
Race, repair, repeat.
Covered many times - most of the time you just need to top off your brake fluid. If that doesn't work then check the pads and rotors like mentioned above.
Old Nov 17, 2014 | 11:13 AM
G37Xtreme's Avatar
G37Xtreme
I think low brake fluid also makes the traction control light come on doesn't it?
Old Nov 17, 2014 | 12:26 PM
mystikal's Avatar
mystikal
Dont top it off
Change your Brakes. Thats the issue.
If you top off your fluid, and then happen to change your brakes...then you will have to remove some Fluid.
This happened to me a few weeks back. The brake light would come on, the VSD would stay on. I changed the Brakes and it went away.
Old Nov 17, 2014 | 01:29 PM
Di3s3l_power's Avatar
Di3s3l_power
WOT throttle is not recommended per owner's manual, try partial throttle and see what happens
Old Nov 17, 2014 | 02:10 PM
ttv36's Avatar
ttv36
If you change your brakes then you should be changing your fluid anyway, so what you say is kind of moot. If the pads and rotors are fine why go all the way to the point of changing them right away? One should start with putting more fluid in to see if that solves the issue. Like you said, as the pads wear down the level of brake fluid needed goes up. But that doesn't mean he needs to replace everything just so the light goes away. Now if OP had screeching/grinding noises or poor braking characteristics when braking that would be a different story..
What you describe with the VDC and SLIP lights also happened to me a few weeks back, but my pads and rotors were fine. All I had to do was rebleed the brakes, I probably had some air bubbles in there from my last brake job.
Old Nov 17, 2014 | 02:54 PM
speedracer g37's Avatar
speedracer g37
The fluid levels is low because the pads have worn down. Adding fluid is a temporary fix since you're most likely due for a pad change. ^why would you change your fluid every time you change your pads?
Old Nov 17, 2014 | 03:37 PM
pdpMIATA's Avatar
pdpMIATA
Top off fluid for now. That is the most direct fix.
Get your brake pads checked. Usually the slip/brake light combo is correlated with a much needed brake pad change and low brake fluid due to that specifically....as mentioned above lol.
Old Nov 17, 2014 | 03:41 PM
G37Xtreme's Avatar
G37Xtreme
You're probably supposed to get a drain & fill on the brake fluid every 15-30K miles depending on how you drive. So it stands to reason that you'd probably have this service coincide with a pad replacement. Not always, but it may be close enough to do both in the same visit to the dealership.
Old Nov 18, 2014 | 11:57 AM
booster's Avatar
booster
What?
Thank you gentlemen. BTW, I've never seen a car that will trip a low brake fluid warning when the pads are worn. The fronts are six months old, don't know about the rear. I'll be checking the fluid and pads.
What type of fluid does the G take?
Old Nov 18, 2014 | 09:09 PM
Di3s3l_power
Originally Posted by booster
What?
jk
check your brake pads and discs,
I had the same symptoms and the rear pads were worn
tomro99
Nov 17, 2015 02:08 AM
inspector94
Sep 8, 2015 12:57 PM
bingpwr
Sep 4, 2015 09:44 PM
ZachThomas
Sep 3, 2015 01:40 PM
