KW V3's?
KW V3's?
Hello everyone, newbie here with a question. I'm looking for KW V3's and I'm getting conflicting information on whether they make a set for the sedans. The part number is 35285007. Some are saying that it will fit out of the box and some say that it is for coupes only. Anyone know for sure? Thanks in advance for any help!
The major reason why most coupe coilovers do not mention sedan fitment is because of where the shock adjustment **** is located. Since the sedan has a "sealed" upper mount, you will not be able to easily adjust dampening unless you remove the damper from the car. Some inverted monotube coilovers have the **** on the bottom, and they will usually say it will fit both models...
Other than that, the suspension is interchangeable
And DOHCtor, you do have a thanks button, it's the lower far right button.
