G37S rear sway bar on X questions
Old Apr 9, 2014 | 11:03 AM
AUR11's Avatar
AUR11
So I have a rear sway that I need to put on my car. What parts can I re-use and what parts do I need to replace in order to make this fit? Thanks!
Old Apr 9, 2014 | 11:15 AM
ANMVQ's Avatar
ANMVQ
? Stock bar, Cause I have one off a XS sitting in my basement. If you bought a after market one it comes with the bushings and you do not have to change the links. I'm still running my stock links and have Hotchkis sways front and rear.
Old Apr 9, 2014 | 11:25 AM
AUR11's Avatar
AUR11
I actually have a 370Z rear sway which is the same as the G37s oem rear sway. The xS comes with a 17.xx mm rear sway and the S and Z come with a 24.xx rear sway from the factory. So I guess I just need to get the OEM bushings for the S rear sway and swap them over and it should just bolt up?
Old Apr 10, 2014 | 08:40 AM
ANMVQ's Avatar
ANMVQ
Yes you would just need the bushing then. Links should be the same again since I didn't change mine with my Hochtkis sways
Old Apr 10, 2014 | 11:02 AM
connoisseurr's Avatar
connoisseurr
What Mike said - your stock endlinks will be just fine. you'll need a different size bushing to allow for the thicker bar. Factory bolts can also be reused.
Old Apr 10, 2014 | 11:10 AM
AUR11's Avatar
AUR11
how about the brackets?
Old Apr 10, 2014 | 11:24 PM
BigBlue's Avatar
BigBlue
Brackets should be the same. The new bushings will be thinner to accommodate the thicker bar, but should fit in your stock brackets.
Please let us know of any differences (good/bad) that you encounter in the ride/performance after the swap. I've been considering this for a while, but will probably go with whiteline since I can't find a 24mm oem bar for less than a whiteline (=$200 shipped).
GW330
Feb 2, 2024 05:41 PM
SkylineG
Intake and Exhaust
13
Oct 3, 2018 07:56 PM
bkouba88
16
Aug 21, 2015 12:44 AM
Jensen Mathew
Aug 16, 2015 08:06 PM
