KW V3 noise after install
Old Apr 1, 2014 | 01:29 AM
G37SBS's Avatar
G37SBS
i just installed KW V3 today but there is a weird noise coming from rear passenger side. The sound is like old box spring. I can hear the noise at low speed... bumps and when i make a right turn.
Is there anyway that i can make the noise go away?
Thanks
Old Apr 1, 2014 | 07:38 AM
Polar_g37s's Avatar
Polar_g37s
Did you make sure everything was tight on the coilovers themselves. I had some one complain about noise the other day and his pillowball mounts were loose. I would double check everything and than go from there.
Old Apr 1, 2014 | 08:47 AM
Maybe you got a set of BC coils painted up like KW?
Just kidding. As mentioned, check your install. Make sure everything is tightened down correctly. If all else fails, completely remove, inspect, and reinstall the spring and the shock on that side. It doesn't take that long on the rears. Maybe 30 minutes.
Old Apr 1, 2014 | 10:42 AM
OLPEMI's Avatar
OLPEMI
subscribed - I have this on my KWV1 rear passenger
Old Apr 1, 2014 | 01:11 PM
terribleone's Avatar
terribleone
I too have this on my KWV1's and I just looked under the car and everything was tight.
Old Apr 1, 2014 | 03:28 PM
SwissCheeseHead's Avatar
SwissCheeseHead
I tend to agree with BB on this one. Usually it's installation as these are high quality coilovers and I wouldn't expect any noise from them if installed correctly. I'm assuming your spring pads and gaskets are all in good shape or replaced? Everything was bolted down snugly (not over tight)?
Old Apr 1, 2014 | 05:00 PM
Rod->Z1's Avatar
Rod->Z1
Endlinks
socialconflicts
May 28, 2020 12:03 PM
b2autodesigns
Brakes/Suspension
128
Mar 24, 2018 07:44 PM
Wikedg37s
May 27, 2016 11:24 PM
cparise
Aug 19, 2015 01:51 PM
SS2006
Aug 11, 2015 10:24 PM
