Bleed your brakes!
Old Mar 26, 2014 | 11:36 AM
Simba989's Avatar
Simba989
Thanks for the reminder. I need to do it because I don't trust my dealer to do it right. Maybe one of these days I'll just rent a lift and get everything done.
Old Mar 27, 2014 | 12:25 AM
Synolimit's Avatar
Synolimit
Originally Posted by Dough1397
How do you know when you've pumped all the old fluid through? That is, how do you know if you've flushed the system?
I bled my brakes once, and just made sure the fluid coming out was clear, roughly ~3 pumps per bleeder.
Some people rotate fluid. Gtr fluid is clear, motul 600 is amber, super blue is blue etc.
I just put clear hose on the bleeders, put them into a bottle, and crack them and let gravity do its thing. Just sit back and watch the reservoir. If keeping the same fluid I think its pretty easy to tell a different shade of old vs new.
Old Mar 27, 2014 | 09:41 AM
Tazicon's Avatar
Tazicon
Originally Posted by mexillis
old thread just curious if anyone actually bleeds their brakes "often"
I have had my current car one year and have flushed the system twice due to running in DE events. I wouldn't do it that often otherwise.
Old Aug 14, 2014 | 12:39 PM
bat6wc's Avatar
bat6wc
How many bottles of DOT 5.1 do I need to perform this service? Does anyone have a link for a good bleeder to buy? Or do local places rent one?
Old Aug 14, 2014 | 01:22 PM
2 pints is probably enough, but I'd suggest getting 3 to be sure. Motive power bleeder (0107) is what you need. Amazon will have one of the cheapest prices.
Old Aug 14, 2014 | 01:26 PM
bat6wc's Avatar
bat6wc
Thanks. I went with the Motive 0117 kit which looks identical. I got the recommendation from a 370z member. Will I be alright?
Old Aug 17, 2014 | 05:13 PM
landslide03's Avatar
landslide03
what kind of fluid should i get from my local autozone? I didnt see any super blue, will any Dot 4 fluid work? Or should I just try to replace it with the exact same kind infiniti put in?
Old Aug 17, 2014 | 05:59 PM
I've had good results w/ this, should be found at Autone/O'Reillys, et al.
Old Aug 18, 2014 | 11:20 AM
landslide03
Cool I am going to order some stop tech pads you reccomended as well!
Old Aug 18, 2014 | 02:31 PM
Yes. That's actually the one I meant. The 0117 has a black label and an metal cap rather then the red label and the plastic cap. Not a huge price difference either.
Old Aug 18, 2014 | 02:47 PM
Since the 370Z brakes are identical to our brakes' hardware and system in every way, here's this helpful video of how to use the Power Bleeder.
Old Aug 19, 2014 | 10:37 AM
blueis300's Avatar
blueis300
Not sure if it has been mentioned but I read you cant mix brake fluid 5.1 with others. Dot 3 and Dot 4 mix is fine.
Old Aug 19, 2014 | 03:07 PM
Correct. It is completely different and cannot be mixed. Just use DOT 3 or DOT 4. That's all you need.
Kojack
Oct 9, 2015 05:53 PM
Mattimus
Oct 4, 2015 01:33 PM
Bennyjoel
Sep 30, 2015 11:56 PM
Soccer4555
Sep 30, 2015 05:31 PM
VIVID
Sep 27, 2015 09:45 AM
