The after math
Old May 16, 2013 | 03:25 PM
Boywdr's Avatar
Boywdr
The after math
I love my new wheels but the I keep thinking I need to stop being cheap and get a camber and toe bolt kit. Will the kit take the slight inward camber look out of the wheels? Or should I leave it be?
Old May 16, 2013 | 04:29 PM
Post your alignment specs again if you can and maybe a good shot down the side line of your car. If you're close and your toe is OK I'd just run it.
BTW, the title of your thread sounded scary, I though you joined some of us in the "recently smashed-up G club
Old May 16, 2013 | 06:56 PM
canucklehead's Avatar
canucklehead
^ +1. where's the photo of a smashed up G? weird title.
check out the Tech section, suspension threads.
Old May 17, 2013 | 04:51 PM
Boywdr's Avatar
Boywdr
Will do tonight
Old May 21, 2013 | 06:41 AM
Boywdr's Avatar
Boywdr
Will do tonight
Angle one ...
Old May 21, 2013 | 06:42 AM
Boywdr's Avatar
Boywdr
Angle two ....
Old May 21, 2013 | 06:44 AM
Boywdr's Avatar
Boywdr
Let me know if you need more
Old May 21, 2013 | 08:46 AM
IMO it looks very good, the rear right camber is a bit low, if & when you go back for another alignment check see if they can get that camber up in the right rear. The fronts are out but they're balanced (w/ the equal amount on each side) and your toe is perfect in front w/ that right rear being a bit low.
IMO your golden, and from the side shots you're squared up real well. That right rear is the only tire that's a bit out from the rest (although it's in spec, it's more out of range compared to it's opposing tire). I'd just run it, but if you feel you really want the front in spec than by all means get just the front arms, the rear is fine and should be able to get that right rear closer to the left without any kits.
Old May 21, 2013 | 10:18 AM
dragion's Avatar
dragion
I'm wondering, does it make a difference that the alignment is based on a coupe and not the sedan?
Looks good to me...not like I know much
Your alignment specs are better than mine and I'm not concerned about it...just let it roll!
Old May 21, 2013 | 01:53 PM
Bota36's Avatar
Bota36
Boywdr, looks good. What size wheels did you get? Also can you post a side shot? I'm in the process of getting new wheels and wanted more ideas/options.
Thanks.
Old May 21, 2013 | 02:11 PM
ttv36's Avatar
ttv36
Race, repair, repeat.
I think -2 camber in the front shouldn't be too bad if your toe is in spec. I ran about -2 camber in the front for over a year without any bad wear on the front. I installed A arms recently and am running -1.5 now.
Old May 21, 2013 | 06:55 PM
Boywdr's Avatar
Boywdr
Sorry I am winging the replies while at work. I was told the alignment it the same so the 2 dr does not matter.
This is one side shot I am gonna post one more from what I have on my phone it's raining hard outside right now.
And I am so 50/50 on the full camber kit it's said cause I can get it for about 475 full front and rear with toe bolts plus 150 installed or save that money an put it towards a new big brakes set up either that's for all the help so far.
Old May 21, 2013 | 06:56 PM
Boywdr's Avatar
Boywdr
And another …
Old May 21, 2013 | 07:22 PM
Sounds like this is one of those things that just "bugs" you, not saying right or wrong, but if you don't feel right about driving your G w/ alignment a bit out then you should just get the front arms and then realign to spec. I doubt you'll truly feel comfortable until all is "right". And I'm in no way being sarcastic or condescending, it's just the way some folks want their ride, and I've got the full F&R kits and am in spec, so I can't really say how I'd feel if I was in your situation. I think I would save the money for something more interesting though
Old May 21, 2013 | 08:43 PM
Boywdr's Avatar
Boywdr
Thanks.
19x8 or 19x9 gotta check again
Rays volk RE30 F1 chrome.
