My bagged 2012 g37 IPL
Old Mar 14, 2013 | 07:59 PM
daren_ipl's Avatar
daren_ipl
Air lift digital autopilot v2 management system
400c compressor
5 gallon tank
3.8 air lines
uas front and rear bags and brackets
ipl suspension shocks
install time 6 hours
Old Mar 14, 2013 | 08:49 PM
G37FrEEk's Avatar
G37FrEEk
looks good man
Old Mar 15, 2013 | 03:57 PM
nassiris90's Avatar
nassiris90
Thats awesome man, congrats. Getting those wheels flush will definitely be the cherry on top
Old Mar 15, 2013 | 04:51 PM
myk1013's Avatar
myk1013
Old Mar 15, 2013 | 08:33 PM
daren_ipl's Avatar
daren_ipl
now with spacers it obvisouly brings the wheel out can i still be that low with spacers? i dont really know anything about "stance" lol im still learning. any help will be great as i have no idea about specs of spacers etc
Old Mar 15, 2013 | 10:30 PM
nassiris90's Avatar
nassiris90
Actually, the answer to your question is pretty interesting. Say in a particular scenario you've lowered your car to the point that the lower control arm makes a positive angle relative to ground (i.e., the lower control arm is NOT level with the ground, as it is angled UPWARD away from the ground). Furthermore, you've properly measured your fender gap, spaced your wheels out, and ensured the tires do not rub the fenders or liners. In such a case, the further your wheel is from the CV joint of the drive shaft (i.e. the more it is spaced out), the lower your car will actually sit. Cheers
Old Mar 15, 2013 | 11:20 PM
mr_nlu's Avatar
mr_nlu
looks great man!
Old Mar 16, 2013 | 07:41 AM
daren_ipl's Avatar
daren_ipl
Thanks nassiris for the info ,
Can anyone tell what size spacers id need? how how do I measure to find out is there any bad things about having spacers?
Old Mar 16, 2013 | 01:55 PM
Steveoh187's Avatar
Steveoh187
I'm running the X sport coupe 19's which are 19x8.5 +43 all around, if I recall correctly the IPL wheel specs are the same as the regular RWD sport coupe so you would have 19x8.5 +43 up front and 19x9.0 +45 rear. I'm running 20mm spacers on an Eibach drop and could easily have done 25mm. With the amount of negative camber you get when you air out, I'd say you could easily run 25mm spacers all around for a full inch in spacing. Probably even 30mm if you wanted...
Old Mar 17, 2013 | 10:57 AM
daren_ipl's Avatar
daren_ipl
Thanks steve, got any pics of your car I wanna see it with the speakers your talking about
Old Mar 18, 2013 | 05:26 PM
daren_ipl's Avatar
daren_ipl
When I'm driving over bumps I hear a squeaking noise does anyone know what it can be ?
Old Mar 18, 2013 | 06:29 PM
venzz's Avatar
venzz
holy hell... low rider status.
Old Mar 18, 2013 | 07:33 PM
daren_ipl's Avatar
daren_ipl
Thanks venzz just trying something different , but now I'm starting to hear squeaking when I go over bumps, I thinking need more grease around the brackets
Old Mar 20, 2013 | 01:25 PM
  #29
daren_ipl's Avatar
daren_ipl
Anyone else with air ride ?
ericmadGRR
Apr 26, 2016 01:27 AM
Raye D. Ater
Nov 9, 2015 12:58 PM
Landshark
Aug 20, 2015 10:48 PM
pledes23
Aug 11, 2015 10:54 AM
Madorable
Aug 8, 2015 11:13 PM
