Eibach Pro Kit 6394.140 AWD
Old Feb 22, 2013 | 08:35 PM
R1cky's Avatar
R1cky
Question Eibach Pro Kit 6394.140 AWD
I found a used set of Eibach Pro Kit springs for G37x... was wondering how it will look if installed on a RWD Sedan? Thanks in advance!
Old Apr 25, 2013 | 10:14 PM
Skeptic74's Avatar
Skeptic74
They should, they are the same spring as 6388 but come with bump stops and sleeves for the front end of the g37x. Probably use OEM bump stops I presume.
Edit: Sorry thought you were talking about coupe. Not sure about sedan, but probably similar. If you call them they can tell you if the spring models match.
Old May 18, 2013 | 03:00 PM
iShift's Avatar
iShift
Its the same on sedans as well...my friend found out the expensive way. I had g35x eibach springs, he said it wouldnt fit his so he bought ones for rwd. When his springs arrived they were exactly the same as the ones I have
OneSickBlackG
Jan 6, 2016 08:49 AM
TheIvoryG
Sep 23, 2015 02:06 AM
EnYcee-G
Sep 3, 2015 04:35 PM
Andyg90
Sep 2, 2015 06:10 PM
