Review Got my cusco front strut bar.
Old Mar 9, 2013 | 12:00 PM
BosMaSwaG37's Avatar
BosMaSwaG37
On the subject of Cusco vs. GT Spec how does the statement make sense?
Originally Posted by Rad_Slinger
^^^this is true. My GT-spec FSB rubs on the sound barrier. It's annoying, but I'm a function over form kinda guy. Ad no one looks at the engine but me.
Old Mar 9, 2013 | 02:00 PM
IPL 370GT's Avatar
IPL 370GT
I believe he is referring to the hood liner. The part that is attached to the underside of the hood. Protection from accessive heat and it does dampen the sound a little. The GTspec bar rubs the liner.
Old Mar 9, 2013 | 02:10 PM
BosMaSwaG37
I'm reading that he acknowledges the same issue everyone else does with GT Spec but is ok with it because he prefers function over form. I don't understand how that constitutes function over form
Old Mar 9, 2013 | 03:16 PM
Rad_Slinger's Avatar
Rad_Slinger
I simply meant that the GTspec FSB works. It rubs on the liner, but I wouldn't replace it for the cusco fsb that doesnt rub even though it probably works just as well.
(GTSpec)Function...it works even though it rubs
(Cusco)Form....works, but doesn't rub which makes it look better
Function=works
Form=looks good
Thanks, though, for dissecting my simple comment that wasn't directed at anyone, but was only trying to reinforce what was said in the comment above mine.
Old Mar 9, 2013 | 04:37 PM
BosMaSwaG37
I don't need you to explain the definition of function or form. My confusion with your statement is that Cusco is just as functional and your statement implies that the GT Spec bar is functional and the Cusco isn't. I believe that Cusco is functional and form fitted and GT Spec is only functional.
Old Mar 9, 2013 | 04:46 PM
Rad_Slinger
Are you sure?
I completely Agree with you...they are both functional.
And that's why I wouldn't replace my GTspec with the cusco. Because I already have a FSB...and I don't see the need to get another one just so it can look pretty, because other than being JDM, that's all the cusco has going for it...pretty....in comparison to the GTspec.
I don't think I can explain my comment any further to you. If you don't get it, then I'm sorry you're confused.
I guess I'm just gonna have to lose sleep.
Old Mar 9, 2013 | 07:36 PM
BosMaSwaG37
Your statement needed clarification so thank's for giving us one.
Are you sure?
Old Mar 9, 2013 | 09:08 PM
OB G's Avatar
OB G
I also have the GTSPEC bar and noticed it was rubbing at the top. Took off the hood liner, problem solved
Old Mar 13, 2013 | 05:23 PM
tchoke's Avatar
tchoke
noob to modding... my car is stock
but saw this post and thought about a strut bar
does this really make a difference?
if op doesnt mind would you share the price you paid
Old Mar 14, 2013 | 12:41 PM
BosMaSwaG37
It's debatable but it's a really nice mod to get for looks. It's hard to argue that it doesn't serve a purpose. The strut bar, with nice coils and sway bars all as a combo will really make the difference. Not a bad mod at all. I recommend it. I want to say it was like 200 for the Cusco...not sure though. ModBagins, who is a vendor on here, had the best price at one time.
Old Aug 12, 2013 | 03:44 PM
I'm going to bump this old thread, having found someone who removed their hood liner.
  • Is it still removed?
  • Can the liner be removed easily, and just as easily re-installed?
  • Is the car any louder?
  • Isn't the hood liner a safety feature, as well as sound-deadening?
I'm asking these questions for two reasons:
  1. My R2C intake is far more quiet than I would like. Want more noise.
  2. The liner rubs on my GT-Spec FSTB, and I hate that.
[edit] Nevermind. I removed it. https://www.myg37.com/forums/g37-sed...ood-liner.html
Old Aug 22, 2013 | 02:12 PM
GTLAW's Avatar
GTLAW
I have the CUSCO bar! 0 rubbing hood liner was removed! Also 0 rubbing on engine cover. the CUSCO bar is better then GTSPEC. I had the GTSPEC and the CUSCO bar is better built.
G's
Nov 5, 2023 12:01 PM
MJ HINX
Aug 23, 2015 10:30 PM
Bn775
General Tech Questions
Aug 23, 2015 10:56 AM
Jensen Mathew
Aug 16, 2015 08:06 PM
