2012 G37x Sedan - loud drivers side brake noise
Old Apr 12, 2012 | 02:38 PM
jms493's Avatar
jms493
Question 2012 G37x Sedan - loud drivers side brake noise
I don't know what the hell this noise is but it just started on the drivers side. When I apply light braking I get an intermittent squeak/creaking noise. When I press the brake harder the noise goes away, but it sounds terrible during light braking. If I recall correctly it seemed to have started after using the parking brake one time.
I am going to take the wheel off this weekend to see what the hell it is but I am just checking to see someone else has had a similar issue. The car has 3000 miles on it....which is quite annoying.
Any thoughts or ideas?
Old Apr 12, 2012 | 03:34 PM
TheLocNar's Avatar
TheLocNar
You're under warranty. Don't touch it. Let the dealer mess with it.
Old Apr 14, 2012 | 03:56 PM
jms493's Avatar
jms493
Thumbs up
Well I took the wheel off today and looked around and inside the wheel hub there was a black piece of plastic that looks like it should or should have not been there. I mean it was so fragile and shredded up. I thought no way was that making the noise.....well after looking around and trying to simulate the noise, I put the wheel back on. Drove around....noise gone.
hmm......
Old Apr 14, 2012 | 06:50 PM
Phil's Avatar
Phil
So I have 2 ideas. In terms of the shredded black piece of plastic that you found on the inside of your wheel hub, it could've been a hubcentric ring. This can only be the case, though, if you have aftermarket wheels. If you do have non-OE wheels, I would definitely replace the rest of your wheel's plastic hubcentric rings with metal ones. The best (and cheapest) place to buy them is from discounttiredirect.com. If you need to find out the outer diameter of the wheel's hub bores, it can easily be found online.
My second theory is a simple one: loose lug nuts. In theory, though, if they were loose, you would've noticed the noise and some rather serious vibrations whenever the car would coast in addition to the noise you noticed when lightly applying the brakes.
Old Apr 14, 2012 | 07:15 PM
jms493's Avatar
jms493
thank you sir....i will look further into this. I have aftermarket wheels. Not loose lug nuts...they were tight when i took them off.
Old Apr 14, 2012 | 11:35 PM
Phil's Avatar
Phil
Are you still running the IPL G wheels? If you are, you don't need hubcentric rings since that's an O.E. Nissan/Infiniti wheel. Can you take a picture of the black plastic piece that you found?
SiKHG37
18
Sep 14, 2015 01:35 PM
bkouba88
16
Aug 21, 2015 12:44 AM
pcwd
Aug 12, 2015 06:54 PM
kevinmward
Aug 12, 2015 12:09 AM
SS2006
Aug 11, 2015 10:24 PM
