Finally happy with my springs setup (2012 AWD Sedan)
Old Apr 3, 2012 | 08:26 PM
themajesticking's Avatar
themajesticking
I did tons and tons and tons of research on this topic and I ended up fairly happy overall with the end result. This post includes a review of the Eibach 6399.140 and the H&R 53030/53031 on a 2012 G37xS sedan.
Lowering springs are very limited for the 2010+ G37x sedan. The only real spring options are Swift, Eibach, or H&R. Otherwise you are forced to kick out $1000+ on coilovers.
Eibach 6399.140
The ride comfort was superb. Overall handling was improved and smooth. I was not happy with the Eibach 6399.140 drop because the front was not lowered enough and the rear was way lower than the front (over 1" difference). When I had the Eibachs installed, my front fender-to-ground was 27". I had someone measure the Swift springs drop and it was nearly the same. I wanted something a bit lower so I decided to go with H&R springs.
H&R 53030/53031
I heard so many bad things about H&R springs such as: "You will scrape everywhere, you would bottom out everywhere, you will ruin your tranny by scraping, you will blow your struts quickly". The only comment that may be fairly true is that you will likely blow your struts sooner since there is very little strut-travel since it's moderately low.
The H&R front springs lower the front of the car moderately but there is very little travel for the struts. City driving can be jarring if the streets are bad, but suburban neighborhoods and highway driving is fine. This was acceptable for me since I love the drop and the car sits perfect. The main issue with the H&R springs is that the rear H&R 53030 springs will never work on the AWD sedan. They literally slam the rear of the car and the tire was almost completely tucked.
I was forced to keep the Eibach rear springs and H&R front springs and the drop is perfect and I have no problems cornering with the different springrates.
Front: H&R 53030
Rear: Eibach 6399.140
Front: H&R 53030
Rear: H&R 53030
Old Apr 3, 2012 | 08:32 PM
sniper27's Avatar
sniper27
Nice...i prefer the raked look better than the *** dropping look also. Black out the window trims and it will go nicely with your black roof.
Old Apr 3, 2012 | 08:34 PM
themajesticking
Thanks. Good idea
Old Apr 3, 2012 | 11:00 PM
Dj1ofDet's Avatar
Dj1ofDet
First, thanks for trying mismatched springs for all us AWD owners. Personally I like the look of the H&R/ Eibach Combo. I think it does the better job at evenly dropping your ride.
Old Apr 4, 2012 | 01:34 PM
dpattana's Avatar
dpattana
Drop looks nice. What kind of wheels do you have on the car?
Old Apr 4, 2012 | 02:11 PM
botlfed98's Avatar
botlfed98
i totally agree with what you say about the rear H&R springs, just way too low...i put in the energy suspension rubber isolators and looks pretty evened out to me!
Old Apr 5, 2012 | 07:24 AM
themajesticking
20x8" TSW Snetterton
I actually have those installed on the Eibach springs but they made less than 1/4" difference for some reason. You installed them on the bottom of the spring right? I think I only bought them because you posted that in a thread some time back.
Old Nov 23, 2012 | 10:08 PM
TopBeam's Avatar
TopBeam
hey If I purchase the Eibach Springs from Stillen for my 2013 g37x sedan will they fit/work fine for my AWD?
Old Nov 24, 2012 | 12:18 AM
themajesticking
Yes but the rear sags a little lower than the front. I ended up reinstalling the eibach springs in the front since I blew my cv boots with the H&Rs.
Old Nov 24, 2012 | 07:38 AM
TopBeam's Avatar
TopBeam
Thank You for letting me know, I will probably go with your set up I guess.
I seen how TEIN Spring's look on our G Sedan's omg! lol It sag's soooo low I thought my friend's car was on Coil's .
Old Nov 24, 2012 | 08:05 AM
You might want to consider Swift springs, they seem to get the best reviews for the X models (if you can still return your springs that is )
Old Nov 24, 2012 | 09:24 AM
TopBeam's Avatar
TopBeam
I didn't purchase the springs yet this is why I'm asking you guy's .
Old Dec 6, 2016 | 05:32 PM
FairladyZ32's Avatar
FairladyZ32
so are the H&R springs that you used for the front of your vehicle for a RWD model?
I cannot seem to find any H&R springs for the g37x seeing as its an AWD model.
Old Dec 6, 2016 | 09:22 PM
When opening old threads, please click on the user name to see when they were last on the site. OP hasn't been on for over 2 years. FWIW H&R doesn't make AWD specific springs. Welcome to the site BTW.
Old Aug 4, 2020 | 01:31 PM
Edgar Nunez's Avatar
Edgar Nunez
do the lowering springs naturally camber your wheels?
i have a 2012 infinity g37x sedan and have some 19 inch rims that sit a bit wider in the back, if i lower it on springs would it naturally camber to tuck the tip of the tire in?
Dillybar12
Aug 17, 2015 04:52 PM
Motoboat
Aug 16, 2015 04:47 PM
Madorable
Aug 8, 2015 11:13 PM
Abramite
16
Aug 8, 2015 08:35 AM
