G37 vert camber issues
Old Aug 14, 2014 | 03:38 AM
zweetz32's Avatar
zweetz32
Get spc camber bolts and you can adjust the rear camber more then factory. It should do the job.
Old Aug 14, 2014 | 04:50 PM
Pnrymmf's Avatar
Pnrymmf
See the below info i got back from BC about coilovers. Apparently they have a coilover now for the vert:
Robert, we have had a G37 convertible kit for some time. The part number is V-12 and it is $1,050.00 shipped within the lower 48 states. It is currently out of stock so please allow 2-3 week lead time for shipment. The default spring rates on this kit are 12Kg/mm front/8Kg/mm rear.
Thanks,
Scott Clifford
BC RACING NORTH AMERICA
Monday-Friday, 9:30 AM-5:30 PM EST.
1-321-206-6381 TEL
1-800-741-1972 FAX
Old Aug 16, 2014 | 08:43 PM
37vert's Avatar
37vert
I looked up the bolts and watched a couple of YouTube videos on installing them, what I'm not clear on is this; is a modification necessary to the hole for the existing bolts, and these are for the upper control arm right, not the lower?
Truth be told, I'd rather modify the upper control arm in the rear because I actually like where the bottom of the whee sits (just need to push out the top), so I'd rather have a longer (or pushed further out) rear wheel upper control arm ("A-Arm").
JRW370
Buying & Leasing
Apr 8, 2019 09:24 PM
ohmyg1990
General Tech Questions
17
Aug 13, 2015 08:18 AM
Redfire32
Aug 11, 2015 09:05 AM
