suspension Help!!!
Old Oct 31, 2011 | 10:25 PM
Rickblkg's Avatar
Rickblkg
suspension Help!!!
So it just rained here in Il, and I find that my g35X back end coming out each time I take a corner with a little throttle. Does it have anything to do with my sway settings? Or is it because of my tires. My sways are full stiff in front and middle in the rear. I have stock rims with all season tires. Also I have the hotchris sways.....
Old Oct 31, 2011 | 10:57 PM
Dabo's Avatar
Dabo
Interesting.... I just ordered the Hochkis Sway Bars and I'm trying to decide which setting to use on the rears. Can you tell us which setting you used?
Now to your question: There are many things that will increase the car's tendency to oversteer:
- front sway bar is not stiff enough
- rear sway bar is too stiff
- front tires are under-inflated
- rear tires are over-inflated
- rear tires are worn too badly to grip well
If you're using the Hitchkiss bars, and all other factors are determined NOT to be causing your oversteer, I'd suggest backing off on the adjustment for the rear bar. I believe the stiffest setting is outboard (closer to the ends of the bar), so moving the mounting point inboard could help.
So.... which setting are you using?
Tom
2011 G37xS
Obsidian/Graphite
Old Oct 31, 2011 | 10:58 PM
All of the things you mention factor into it. The traction of the tires you have, wet roads, and your sway bar settings. Since it's the easiest (and cheapest) thing to change, try setting your rear sway bar to the least stiff setting to reduce oversteer. Only try one change at a time, to see what it feels like and what is working before trying something else. Experiment to see what gives you the handling that you like for your driving style.
Old Oct 31, 2011 | 11:34 PM
firstinfiniti's Avatar
firstinfiniti
May be your definition of "little throttle" is different than others' lol
Old Nov 1, 2011 | 10:17 AM
Rickblkg's Avatar
Rickblkg
Tom and bb thanks again thats what I figured I will try that and ^first by a little i mean a little more than normal lol. Also Tom the front is full stiff and rear are in the middle. But in dry condition I have no problem it just happens when it rains
Old Nov 1, 2011 | 11:14 AM
MACS's Avatar
MACS
All season tires are not performance summer tires. That alone can make a world of difference.
Old Nov 1, 2011 | 11:22 AM
dkmura's Avatar
dkmura
20 Year Member
Remember that the Infiniti AWD system is rearward biased, so you'll get higher slip angles in the rear as a result. Adding stiffer swaybars will only accentuate that. Try setting the rear sway on full soft or disconnect it completely to see a difference.
Old Nov 1, 2011 | 08:36 PM
OB G's Avatar
OB G
Definitely sounds like an issue with tires then. How much tread do you have left? How many miles have you driven on them?
Old Nov 1, 2011 | 11:18 PM
Rickblkg's Avatar
Rickblkg
Tires where brand new when I bought the car and since have put about 5-6K. Their a no name company Milestar (Sport) something.
Old Nov 2, 2011 | 12:07 AM
mikelr's Avatar
mikelr
Tom
2011 G37xS
Obsidian/Graphite
Just a clarification on this post; to soften the rear bar you would choose the holes at the end of the bar not the inner holes.
You may want to do nothing more than adjust your driving style in the rain. I can see all you speed racer types driving your G's out on the street like your on a closed road course. If you are sliding out the rear of your car in the dry or the rain, you are driving too fast!
That's it...I officially sound like an old man!!!
Old Nov 2, 2011 | 10:25 AM
Rickblkg's Avatar
Rickblkg
^ Mike that was a definitely an old man comment, and to get it clear i wasnt driving fast at all ive taken corners in the rain a lot faster in my Altima... im talking from a dead stop making a turn at like 15 mph with a little throttle.....
Old Nov 2, 2011 | 05:31 PM
OB G's Avatar
OB G
LOL a responsible old man
OP-get new tires.
Old Nov 2, 2011 | 08:37 PM
Dabo's Avatar
Dabo
Originally Posted by OB G
OP-get new tires.
LOL! Yeah, I hear the OEM Dunlops are pretty useless for real performance and for snow. Kind of an in-the-middle compromise that gives you the worst of both worlds
I'll be getting some nice summer tires when these burn off. For winter I'm nearly ready to get a wheel/tire package with some aggressive snow tires. No doubt I'll be much better of on both ends.
Old Nov 2, 2011 | 09:31 PM
Itchytoe's Avatar
Itchytoe
Read through the whole thread, and I agree with OB G on all accounts. Yea, mike, you sound like an old man, but it's completely warranted. You shouldn't be sliding around if you're not trying to. And OP, get new tires. I'm 110% sure that's your problem. No name all-seasons means trash.
Old Nov 3, 2011 | 10:55 AM
Tsugumo's Avatar
Tsugumo
Nankang Milestars look to be very cheap Chinese Tires. I think you will find a world of difference with a set of quality performance tires. Good luck!
