Eibach 6383.140 for 07 on 09+ Sedan?
Old Oct 20, 2011 | 08:45 PM
rod_b's Avatar
rod_b
Anyone know if a sedan kit for an 07+ G35 (6383.140) work on a 09+ G37?
Old Oct 21, 2011 | 12:48 PM
rod_b's Avatar
rod_b
If this info helps anyone...
Called Eibach. Said the rear springs are actually the same part number. The front max spring rate for the G35 kit (6383.140) is 480lbs while the front for the G37 kit (6390.140) is 548lbs. Same min spring rate...280-ish. I don't remember exactly. The guy said the probable result is that the front may sit slightly lower at rest and be slightly softer driving.
Old Oct 23, 2011 | 01:59 PM
This may help~I purchased B&G S2 springs for an 07-08 G35 which were rated as a 1.4" drop F&R, I ended up w/ the perfect drop IMO, it came out to 2" Front and 1.5" Rear.
I'd imagine the Eibach kit for an 07-08 would perform about the same giving you an additional 1/2" drop in the fron and the rear wouldn't change from the 07-08 drop.
Old Oct 23, 2011 | 02:31 PM
tejasg37x's Avatar
tejasg37x
Did you wet sand and buff the paint on your car? It sure doesn't look like the typical orange peel paint on Infiniti...
Old Oct 23, 2011 | 02:47 PM
No, the orangepeel is still around, not too bad, but for an upscale brand you'd expect better. I'm ashamed of the paint chips on the front, now that's really a bummer
Old Oct 24, 2011 | 12:55 AM
rod_b's Avatar
rod_b
Beautiful G. Nice drop. Off topic but yes, the paint is quite disappointing
Chances
Apr 28, 2020 07:52 PM
Ricio1991
Oct 17, 2018 11:24 PM
Tunerz_Store
Brakes/Suspension
117
Jul 16, 2018 02:04 PM
G37xhibeet
Nov 15, 2016 09:29 AM
m3clubracer
Aug 19, 2015 03:48 PM
