creaking noise front passenger
I installed a spc front camber kit and also have eibach springs and front sway bars recently I've been hearing and feeling a creaking noise while usually slowly pulling in driveways I guess when the wheel flexes it creaks, im not sure if it could be the camber kit bushings or maybe the springs that may need some grease, anyone have any suggestions??thx
I have swaybars and they will creak if they are not greased. I had the same creaking problem when backing off my driveway, but ones I greased it, it went away. That might be your problem...
You have to grease the inside of the rubber bushing. It's the 2 rubber part that holds the sway bar. You can either get a grease gun and stick it to the nipple connection or you can just take that whole piece off and grease it. My grease gun sucked so I just took it off, which didn't take that long. Make sure you put a a lot. I used silicone grease which I bought from this site:
https://www.motionindustries.com/mot...ductSearch.jsp
Hope that solves your problem.
tite_tite
Aug 22, 2015 05:21 PM
