New Rotors and Pads. Softer pedal
Old May 9, 2011 | 04:55 PM
themajesticking's Avatar
themajesticking
So this weekend I installed my drilled/slotted rotors from brakeperformance.com and I ordered all new stock pads from infinitipartsusa.com. This was my first time installing rotors on the G so I used the service manual and it wasn't too bad. Everything was installed fine but I noticed that my pedal is WAY softer. The car stops fine but I have to push the pedal way farther than I did with the old pads. The pads looked identical except the new pads had the metal noise thingy and the old pads didn't. I have no idea what the problem could be.
Old May 9, 2011 | 05:24 PM
buffpatel's Avatar
buffpatel
It sounds like you might need to bleed the brakes. I'm no car expert by any means but I have heard of air getting into brake lines causing softer pedal. Did you change the calipers with the rotors and pads?
Old May 9, 2011 | 05:33 PM
themajesticking
That's what I was thinking but I'm not sure. In order to install rotors you do have to disconnect the brake line from the caliper though. I kept the stock calipers
Old May 9, 2011 | 05:37 PM
dal1307's Avatar
dal1307
If you disconnected the brake lines then you need to bleed them.
Old May 9, 2011 | 05:46 PM
Gee37S's Avatar
Gee37S
As soon as you disconnect them it's only logical that some air would get into the lines. Bleed the brake lines and let us know if it fixes it!
Old May 9, 2011 | 05:49 PM
themajesticking
I have no idea how to do that and the FSM is kinda vague
Old May 9, 2011 | 06:02 PM
Chomponthis's Avatar
Chomponthis
Check all your brake hoses and make sure you bleed just to be safe. Cap is on correctly on the cylinder. First thing i would do.
Old May 9, 2011 | 06:03 PM
Gee37S's Avatar
Gee37S
Proper Brake Bleeding Procedure - 6MT.net Infiniti G35/G37/GTR Forums
Old May 9, 2011 | 09:43 PM
themajesticking
Cool thanks
Old May 9, 2011 | 09:44 PM
themajesticking
Wow. Looks complicated! I will try it this weekend. Thanks!
Old May 10, 2011 | 08:44 AM
themajesticking
So I need to buy a bleeding kit or something?
Old May 10, 2011 | 08:48 AM
Gee37S's Avatar
Gee37S
Looks like it. Or you can just ask a garage to bleed your brakes, less of a headache I imagine. Plus brake fluid will ruin your paint i it touches it.
Old May 10, 2011 | 08:50 AM
akuma_83's Avatar
akuma_83
Speed Bleeder Bleeding Brakes Bleeding Motorcycle Brakes Automotive Bleeder Screw Brake Bleeder
^ Or you could try these ! I ordered them, but just dont have time to install, too busy of a schedule with the gym, work, kids, BJJ... If you search, some other members on here have had success with them. Check it out ! GL bro !
Old May 11, 2011 | 10:16 AM
philter25's Avatar
philter25
Did you bed in your brakes? I had my rotors and pads replaced per TSB and I had to do a few hard stops, from 60 down to 10, to bed them in pretty good before they started to have bite again.
I had to press my pedal 75% down before it started to bite. Now it bites at 25% depression and feels just like stock.
Old May 11, 2011 | 12:03 PM
themajesticking
yeah I did do that just to make sure but it's still not where it should be. Considering the process of removing the calipers i'm pretty sure there's air in there. I guess I will find out this weekend.
