Bc racing
Old Mar 31, 2011 | 03:05 AM
OMG35S's Avatar
OMG35S
Exclamation Bc racing
I'm considering picking up a set of BC Racing Coilovers.
I've heard a lot of mix reviews. A lot of horror stories about the noises, creaks, leaks, sags, rear dumped, etc.
Then there are people who had 0 issues with them and are happy.
What's the final verdict on these coilovers? Are they worth picking up used?
Has anyone replaced their struts through BC for leaks, creaks, etc....?
Thanks!
Old Mar 31, 2011 | 07:35 AM
soundmike's Avatar
soundmike
I've had mine for about 14k miles now and have experienced no issues whatsoever. It's gone through sub-freezing temperatures all the way to typical Texas summers.
And as Houston goes, potholes and road ruts that makes you cringe.
The one on my car is i guess what you'd call Version 1 where the rear struts had the adjustment ***** at the top (i.e. run the extension cables through to either trunk or cabin, depending on whether you have a coupe or sedan). The V2's have the adjustments on the side, so you'd just have to raise the car and reach under to adjust from outside.
Also, i believe BC now also offers a higher sprung but taller rear spring so you can raise the car back to OEM spec. The one i have, 230mm IIRC, is a mixed bag. The fronts can raise up to higher than OEM, but the rears will certainly not.
Old Mar 31, 2011 | 02:04 PM
platinumg35x's Avatar
platinumg35x
^ I have the 255 spring for the rears (they just started offering this) and you can raise it a lot higher (probably almost as high as a stock - excluding the awd). get them installed properly and you shouldn't have any issues
Old Mar 31, 2011 | 03:47 PM
Mike's Avatar
Mike
Thanks!
What are you looking to get out of the coils?
The #1 reason people buy these is because they're cheap.
Old Mar 31, 2011 | 04:02 PM
Steveo47's Avatar
Steveo47
^^ or you have a AWD coupe and have no other option.
Old Mar 31, 2011 | 04:37 PM
soundmike's Avatar
soundmike
Thanks for the confirmation! I wonder if they'll let me swap my 230's with those 255's. What's the spring rate on those?
Old Mar 31, 2011 | 05:19 PM
da mayor's Avatar
da mayor
talk to Vinny Ten Racing... he's an authorized distributor vendor and installer for them.... got a nice deal on them right now for $1299 installed and adjusted
Old Mar 31, 2011 | 05:34 PM
Steveo47's Avatar
Steveo47
i paid 925 (not including shipping) for mine.
Old Mar 31, 2011 | 05:54 PM
KauseKaos's Avatar
KauseKaos
I've been wondering the same thing.
Old Mar 31, 2011 | 05:56 PM
OMG35S's Avatar
OMG35S
Pretty much regular street driving...
BC seems to be the best bang for your buck on the forums...
Old Mar 31, 2011 | 06:00 PM
OMG35S's Avatar
OMG35S
I don't like that they've had so many issues. It seems as though BC has been addressing the issues slowly.
Old Mar 31, 2011 | 06:48 PM
Mike's Avatar
Mike
At the risk of bringing up an age old argument, you do get what you pay for.
If all you want to do is drop the car a bit with some adjustability, these will do that just fine. If you're looking for an improvement in handling, well, that's subjective.
Old Apr 1, 2011 | 09:10 AM
soundmike's Avatar
soundmike
Mike, i'm curious, what makes you say that about the BC? (i.e. BC and handling).
The BC's may not be along the lines of Bilstein, and I don't frequent the track as much as you, but i do find the set to be quite an improvement over the stock suspension.
Old Apr 1, 2011 | 10:16 AM
Kidcane's Avatar
Kidcane
Florida G Club
Mike is a brand *****. BC's will def improve the handling of your car. Now if you are raping your car on the track you may want to go a little higher end.
Mike's Avatar
Mike
Most people perceive any change in ride/feel to automatically be better, but in the big picture, suspension means very little in terms of actual performance gain.
Using sticky tires for the rest of the life of the car would have a far larger effect on handling at likely a cheaper price (compared to keeping OEM tires on the car forever).
To put it in perspective, if we were to try to quantify the performance gain at the track, a small wing would do more for virtually all cars than the fanciest suspension you can buy. We're talking $80 ebay special wing versus $15k 3 way adjustable fully customizable shocks with remote reservoirs. The difference having a better tire would make is larger than the difference a wing would make.
Now, if you just prefer a harsher ride, you can make the car ride harsher with tires as well...
I still use stock suspension on my track car, because there is no performance gain to be had unless I'm willing to shell out 4k+. This debate happens daily elsewhere
