All my Dashlight are on for some reason.
Old Feb 23, 2011 | 06:15 PM
CateyeRR's Avatar
CateyeRR
Originally Posted by xoxomichelle
I have that same problem too. Took mine to the dealer a couple months back, and they just said when you accelerate quickly the floating sensor for the brake fluid thinks it's close to empty so they said to fill it up. Haven't gotten around to it yet though since they told me it was no big deal..?
This is exactly what it is. Just low fluid, same thing happened to me after i took it to the track. I assume I wore off a bunch of brake pad, therefore there the brake cylinders were pushed out farther making more room for fluid. So the reservoir level dropped and triggered the lights under hard acceleration. Just fill it up with a dot 4 brake fluid and it will be fine, even mixed with the motul. Unless you are really **** or see a lot of track time, then order more motul. DO NOT use dot 5, that is silicone based and will royally f your system over time. I'd keep checking the level every couple weeks to see if it keeps dropping.
Kojack
Oct 9, 2015 05:53 PM
dan1stgtn
Apr 14, 2012 06:12 PM
darryl865
Picture Share G Coupe
23
Apr 6, 2012 04:18 PM
