Service Manager from Infiniti regarding Eibach Price info and price of labor.
Old Dec 14, 2010 | 01:16 PM
marcelo19lp's Avatar
marcelo19lp
I got this email from the service manager from a local Jersey Infiniti Dealer, what you guys think?
Thank you for contacting us, we normally do not get involved in installing aftermarket parts and accessories due to inconsistencies in fit, quality and reliability, and if we do we would charge based on time and material, most aftermarket installations require adjustments and or modifications for proper fit.
According to my information front spring replacement requires 1.5 hours of labor @ $110.00/hour plus any additional time required to insure proper installation, rear springs are 2.5 hours, an alignment may be required if the new springs alter the ride height of the vehicle.
Installing aftermarket parts may also alter the ride quality, effect tire wear and or longevity of suspension parts and may void the warranty of the previously mentioned parts.
If you request that we install the springs we will offer no warranty on the parts or labor of the installed parts or damage caused by altering the vehicle, the only coverage would be whatever is provided by the manufacturer or supplier of the aftermarket parts.
Please let me know if you are interested in having us do the installation.
Thank you,
Old Dec 14, 2010 | 02:07 PM
Steveo47's Avatar
Steveo47
Thank you,
Weird, Ericksen infiniti (edmonton, alberta) has an entire section on their website how they will instal aftermarket parts for you and will cover any damages associated with the LABOR. How can they say they dont warranty the labor... and if they kno what they are doing, it will NOT take them like 5 hours to do it.
Old Dec 14, 2010 | 02:11 PM
beerme986's Avatar
beerme986
$550 for just install is crazy. I paid 500 for springs, install and alignment (good shop so no camber kits required)
Old Dec 14, 2010 | 02:14 PM
Steveo47's Avatar
Steveo47
Theres no way that a good alignment shop can get your camber back to specs after you lower your car, the stock are not adjustable at all
Old Dec 14, 2010 | 02:33 PM
ReddieG37's Avatar
ReddieG37
why would you get them installed at the stealership? i would go to any reputable local shop to get them installed for much cheaper.
Old Dec 14, 2010 | 02:49 PM
Kidcane's Avatar
Kidcane
Florida G Club
I think you are wrong. Rear camber can be slightly adjusted from the factory and with a 1" or less drop can get back close to factory setting.
Old Dec 14, 2010 | 02:51 PM
Kidcane's Avatar
Kidcane
Florida G Club
To the OP, if anything do the rears yourself, they are SUPER easy and will NOT take 2.5 hours. The front are much more difficult as they require a spring compressor and removing the entire shock and spring combo.
Old Dec 14, 2010 | 03:42 PM
Installing rear springs on the rear of this car takes no more than 30 minutes start to finish even for a retarded monkey. They don't even require a compressor. The fronts take longer and are more difficult than the rears. He's simply quoting the time his book says it takes (which is obviously wrong). Don't let them install your parts. That's too much. I install spings on G's regularly (did 2 sets last week). I charge around $225.
Old Dec 14, 2010 | 03:43 PM
Steveo47's Avatar
Steveo47
Well I know the fronts are defiebitly not adjustable.
Old Dec 14, 2010 | 10:52 PM
marcelo19lp
Any shops u guys know of in NorthEastern Jersey?
Old Dec 15, 2010 | 01:29 AM
beerme986's Avatar
beerme986
rears are adjustable. such a mild drop you can get it close to spec. if your in north jersey, might wanna check out new york as the car scene is bigger there. check out g35 nyc's forum.. probably find a place there
Old Dec 15, 2010 | 01:58 AM
Doggy's Avatar
Doggy
Just get someone off the forum to do it, then get an alignment.
Old Dec 15, 2010 | 02:24 AM
GraphiteG37S's Avatar
GraphiteG37S
Damn stealerships at it again!!! Lol. Find someone local. Or DIY...
Old Dec 15, 2010 | 08:30 AM
EnviedG35's Avatar
EnviedG35
I installed my Eibachs in the rear myself. Literally took me 20 mins to do both sides with just car jack. I paid $60 to have the fronts installed since that requires more tools i just didnt have. They're crazy!! haha
Old Dec 15, 2010 | 10:22 AM
123u's Avatar
123u
This original posted by Ruckus12251985 in Northeast Section.
There are always people asking what shops are good. If you in north or central NJ I highly recomend JPC Auto. Great service and great prices. I get my normal maintainence, oil change etc done there. My eibach springs were installed there, then my tanabe coils. Also got my tires (falken fk452) through them, same day & good price, and they mount and balance them.
I just like they treat your car like its theirs. I call up and they tell me what time to come and I just pull right on the lift and get to watch the work being done.
I will be going back when I get my sways and gt spec braces.
Here is the info for them:
JPC Auto
1033 Garfield Ave.
Jersey City, NJ 07304
call Chris (201)388-0029
If anyone wants I will ask for a list of common installs like cat back exhaust, hfc's/test pipes, camber kits, brake pads, rotors.
It was $175 for coils installed and adjusted to the height I wanted.
send a PM to Ruckus12251985 if u have any question.
