best soloution for brake squeal
Old Oct 6, 2010 | 07:19 PM
ruckus12251985's Avatar
ruckus12251985
i've had the brake squeal come and go but its been bad recently, (only in reverse) I only have 13k on the car ALL city miles, the last time I had my front rotors off I saw that the pads are still good but need to be changed somewhat soon, and the rear pads were good. The sqeal drives me nuts, so what should I do?
try new pads hps?
or
adams rotors is having a deal get rotors and pads?
(street rotor double slot/drilled with hps pads) pretty good deal too
I just want the squeal gone any one with either combo please give me ur review thanks in advance
Old Oct 8, 2010 | 02:38 PM
babyxgk17's Avatar
babyxgk17
"Not Uncommon"
I brought my car into the dealer the week after I got my brand new car. The brakes squealed in reverse EVERY TIME. They said its normal because of the brakes. I have a 2008 g37s.....it's been 2 years....and still the same thing. It so embarrassing everytime i reverse. I HATE IT!!
Old Oct 8, 2010 | 03:06 PM
GraphiteG37S's Avatar
GraphiteG37S
Mine don't squeal in reverse although I believe it's a common problem with a lot of Nissan models. The 350z does it all the time.
Old Oct 8, 2010 | 03:35 PM
Gyoza's Avatar
Gyoza
Try swapping to a low dust ceramic pad.
Old Oct 8, 2010 | 05:33 PM
ruckus12251985
mine comes and goes, it seems worse when its colder. i hate it so much that I might just get the rotors and pads.
but if it squeals with the new rotors and pads ill be pissed
Old Oct 13, 2010 | 06:16 PM
jungwoo0622's Avatar
jungwoo0622
go get the brake cleaner kit and brake caliper grease.
clean it and install it again with care.
It will give you better braking and no more noise.
Old Oct 13, 2010 | 09:54 PM
rAvi665's Avatar
rAvi665
i got so tired of it. I just use the ebrake everytime I reverse. No squeal.
Old Oct 14, 2010 | 11:24 AM
ruckus12251985
lol probablly the best soloution, instead of spending all the money when I don't NEED rotors at all yet.
Old Oct 14, 2010 | 11:53 AM
The Jewbag's Avatar
The Jewbag
I got it fixed under TSB 5 times. It still squeaks.
Old Oct 14, 2010 | 09:07 PM
Stylin G's Avatar
Stylin G
I just had my 08 g37s coupe to the dealership yesterday to fix my front brakes. The rotors were warped and they did all the work according to the TSB. I told them about the squeal in reverse and they gave some excuse that the sport brakes were generally louder.
When I picked the car up they said they cleaned off my pads and I haven't heard the sound yet, which was really horrible lately. They also replaced my wheel bearings since they had it all apart. Guess I drive a little too hard. Only 17k miles too.
Old Oct 15, 2010 | 03:42 PM
toastmaster's Avatar
toastmaster
Clean the brakes thoroughly.
I have the 6MT coupe, and the last time I took it in for service, they inspected the brakes. Afterwards, the car would squeal everytime in reverse (not just when cold), so I eventually took apart the brakes and gave them a good cleaning. The noise is all gone now
Old Oct 15, 2010 | 04:46 PM
cvipgo's Avatar
cvipgo
what if you use high pressure air blower to remove brake dust?
Old Oct 18, 2010 | 12:19 PM
APRacing-ChrisB's Avatar
APRacing-ChrisB
The best stuff we've found so far is the Permatex Ceramic Extreme Brake Parts Lubricant: http://www.permatex.com/products/aut..._Lubricant.htm
Make sure you clean up all areas where the pad back plate touches the caliper cage, piston and caliper. Apply the purple stuff just like the instructions say and the noise should be gone for quite some time. Nothing works 100% every time on brake noise, but this has been pretty close! I've seen it in more and more parts stores lately, so it isn't too hard to find.
Chris
Kojack
Oct 9, 2015 05:53 PM
Mattimus
Oct 4, 2015 01:33 PM
Bennyjoel
Sep 30, 2015 11:56 PM
Soccer4555
Sep 30, 2015 05:31 PM
VIVID
Sep 27, 2015 09:45 AM
