My G lowered on Eibach Pro-kit
Old Sep 22, 2010 | 09:32 AM
JJSoCrazy's Avatar
JJSoCrazy
Nice drop looks gr8! How much of a drop is it and where can I get a good deal on Eibach Pro-Kit?
Thanks
Joe
Old Sep 23, 2010 | 12:18 AM
4drScreamer's Avatar
4drScreamer
How's the clearance for daily driving? I lowered my '05 TL and loved the handling improvement, but had a he'll of a time bottoming out. Even at 45's through humps and dips. Similar Eibach springs though and they were great. I am however considering coil overs for my new '10 G37S sedan. Any thoughts or recommendations?
Old Sep 23, 2010 | 12:36 AM
smalls'g37's Avatar
smalls'g37
ah..these cars look sooooo much better with a drop. looking good man.
Old Oct 9, 2010 | 02:27 AM
evilpanda's Avatar
evilpanda
Thanks
Joe
thanks! drop is 1.5 front and 1.2 in the rear. i got my springs off ebay and picked it up locally.
clearance is not that bad, it handles so much better. never had coils so can't really say anything about them.
thank you.
Old Oct 9, 2010 | 07:45 PM
terrycs's Avatar
terrycs
Very ironic .. Eibach R&D is in Corona. Looks good!
Old Oct 10, 2010 | 10:53 PM
eksigned's Avatar
eksigned
looks great! can you though, tell us what your alignment specs were? i'm debating on coilovers or springs. springs are cheaper, and they give the ride height that i want - i won't be tracking the car or racing it heavily, so i'm shy away from coils. terry mentioned that he had to get caster arms to get everything into spec, but i'm happy with a 0 toe and a bit of camber.
Old Oct 11, 2010 | 11:27 AM
Austin713's Avatar
Austin713
I am curious as well. the camber arms are like 250 bucks, which is even more than the springs....
Old Oct 11, 2010 | 12:05 PM
MPULSE's Avatar
MPULSE
So, are rear and front camber kits recommended if you choose to go w/ Eibach PK springs? I've searched but couldn't find an answer.
Thanks.
Old Oct 11, 2010 | 01:44 PM
movinon's Avatar
movinon
thank you.
Is the 1.5" front / 1.2" rear the measurements you took when the springs were first installed or later after they had set in and dropped a bit more?
Could you post another picture, now that the springs have had some time to set, similar to the ones that you took when the springs were first installed.
Old Oct 11, 2010 | 02:01 PM
evilpanda's Avatar
evilpanda
thanks.
i haven't done the alignment yet, i've been busy. i'll try to do it within this week.
the 1.5/1.2 is the drop rate from the Eibach website.
more pics on the link below. |v|
https://www.myg37.com/forums/picture...m-factory.html
Old Oct 11, 2010 | 02:37 PM
sportsdude512's Avatar
sportsdude512
Looks really good man!
Old Oct 11, 2010 | 03:57 PM
eksigned's Avatar
eksigned
thanks.
sweet panda! thanks for evening getting back to us. if worse comes to worst, make sure that the toes are in 100%. figure out the camber stuff later. more than likely..you'll need kits, i'm assuming albeit negative camber really doesn't do anything to the tires as long as your toe's in. not sure about caster.
by the way, ive hada 2010 g37x loaner for the past weekend, and BOY DOES that thing take off off the line. i'm REALLY enjoying the car! it's been raining like CRAZY here this past weekend. x sure does do the job! you have a NICE CAR!!!
Old Oct 11, 2010 | 06:49 PM
MOB's Avatar
MOB
for those looking for the Eibach PK....go to Import DPS
FYI - I got my '09 G37s sedan springs from them for $221.xx shipped to my door. Just gotta find somewhere to put them on for a reasonable price....
BTW OP....did you put on any spacers? Once mine is dropped, I think I'm going with 15mm or 20mm to flush the wheels.
Ride looks good man, your pics right after you put the springs on made me pull the trigger.
Old Oct 12, 2010 | 12:48 AM
  #29
terrycs's Avatar
terrycs
Thanks.
I would recommend it if you don't like dealing with dismounting tires for side to side rotations.
Old Oct 12, 2010 | 04:14 PM
  #30
MPULSE's Avatar
MPULSE
yea true. Thanks
