Wheel alignment. Socal SFV
Old May 24, 2010 | 04:52 PM
TVPostSound's Avatar
TVPostSound
Looking for someone in the SFV area Socal, to do a wheel alignment.
I've searched, and only found the 2 in Gardena, and Industry.
Please, no Firestone stores, thanks.
Old May 24, 2010 | 05:00 PM
Mike's Avatar
Mike
How far are you willing to drive for an alignment?
Do you have a front camber arm?
Old May 25, 2010 | 12:16 AM
yogregb's Avatar
yogregb
How about Stillen in orange county??
Old May 26, 2010 | 02:10 PM
TVPostSound
As in my OP:
SFV
Old May 26, 2010 | 02:33 PM
Mike's Avatar
Mike
The recommendations (as well as the requisite long drives) come with a reason: those shops know what they're doing.
You can go to your local mechanic/firestone/walmart and get an alignment that is "in spec", or you can work around Evasive/West-End's schedules, drive an hour, and get an alignment based on what you tell them you want.
You did buy a G and not a Genesis, didn't you? Don't skimp now.
Old May 26, 2010 | 03:47 PM
TVPostSound
Let me rephrase:
I'm looking for a lowered friendly performance alignment shop, in or near the
San Fernando Valley. There has to be more than 2 shops in the LA area that qualify. (West End Evasive)
I am not looking to skimp.
I just don't have the time to drive out that way, it's more than an hour via the 405
BTW,
As I stated, I wasn't looking for Firestone stores.
I was a brake/front end/alignment tech in my former life.
I've seen how guys can bump the heads of the Hunter in order to put the camber in spec. (on paper) . It then results in the toe calibration also being off.
Old May 26, 2010 | 04:13 PM
Mike's Avatar
Mike
Temple City Auto is closer to you, but it's still not super close.
Evasive/West End will allow you to watch and explain everything they're doing as they're doing it if you ask.
They both also lower the tolerances when they dial in your setup; "in spec" is not "spot on", and they do "spot on".
jfisher
Apr 25, 2017 01:22 PM
tomro99
Nov 17, 2015 02:08 AM
youngGeezy
Sep 3, 2015 08:01 PM
