SPC Camber Install/Alignment
Old Feb 11, 2010 | 09:20 AM
Bird_Jenkins8's Avatar
Bird_Jenkins8
So, I've recently added Tein S-Techs along with some Vossen 084's. Noticed a significant camber in the rear, so I went ahead and ordered the SPC rear camber kit. Took the car to NTB here in Grapevine after the good work they did mounting and balancing my new wheels and tires without destroying the lip of the wheel and also due to the road course warriors that work up there. Asked to have an alignment done as well as the rear camber arms installed. The guy ask me what specs I wanted the wheels within and I said just the stock Infiniti specs.
Go to pick the car up and the guy who did the work has all four corners sitting with a slight negative camber because the guy states it's better for a lowered car. Asked to see the spec sheet and not one corner was within spec. I'm just wondering if any of you running SPC components are running slight negative camber at all. I know it gives better handling qualities in some instances, but I'm not road racing the thing and merely use it as a daily driver.
I don't have the spec sheet on me or a side pic of the car from any angle that will show it, but from the side of the car looking from back to front or vice versa you can definitely see a slight negative camber.
Here's a pic of the car pre alignment/camber arm install so you get an idea of the stance if anyone cares.....
Old Feb 11, 2010 | 11:10 AM
jarborn1's Avatar
jarborn1
No, the reason i bought the SPC rear kit was to bring the wheels back to within spec..
My front's are ever so slightly out of OEM spec but i am not all that worried about that as my TOE which is what really digs into the tires are all OEM..
I would go back and have him put the rears within and the fronts as close to oem as possible..
Old Feb 11, 2010 | 11:45 AM
mishmosh's Avatar
mishmosh
Sounds like they were too damn lazy to get it right. I would definitely go back. With the SPC rear, you can easily get it to the middle of the spec range.
Old Feb 11, 2010 | 01:13 PM
ReddieG37's Avatar
ReddieG37
you bought the spc rear camber kit to put the rear camber back within specs. if they didn't put it back within specs, what's the point of the rear camber kit?
i would go back if i were you and tell them to realign your car.
Old Feb 11, 2010 | 01:19 PM
beerme986's Avatar
beerme986
tell him to align it back to stock setting or get your money back and find a performance shop that will do it. chain stores like pep boys can only align factory cars so dont bother with them.
Old Feb 11, 2010 | 02:16 PM
Bird_Jenkins8
My thoughts exactly.....what gets me is they asked what specs I wanted them aligned to and I said within the stock Infiniti specs. Only to find out when I went to pick it up, the specs weren't even close.
Also noticed on my way to College Station, the alignment was off....its pulling to the right. They had it from 7 AM to 4 PM and did nothing correctly....
Old Feb 12, 2010 | 11:03 PM
xevious10's Avatar
xevious10
get the alignment done again that is rubbish
Old Feb 13, 2010 | 11:12 AM
maxipad96's Avatar
maxipad96
I wasn't able to get my car back into specs after the H&R/SPC combo either. It was way better after SPC but still slightly out of spec. The lower the spring the less even a camber kit can do. I got mine aligned at perhaps the most well known shop in Atlanta for Alignments. Just a casualty of war.
Old Mar 17, 2010 | 08:51 AM
cereal2k's Avatar
cereal2k
Mr. Drop it like it's hot
What's the well known alignment shop in the ATL?
jfisher
Apr 25, 2017 01:22 PM
Kojack
Oct 9, 2015 05:53 PM
Allboutcali
Sep 26, 2015 03:43 PM
jfisher
Sep 8, 2015 04:16 PM
