I would get drilled, simply because they look better. They will not crack unless you are heavily getting on the brakes, which 99% of the people on here do not do.
Wow! This really shows you how much a a value the sport package is. It's crazy when you think that the BBK costs a mere $200 less than the entire sport package.
Anyway, regarding the brake hoses, I would try to find the part numbers for the standard brakes and check them against the sport brake hoses. If they are the same, I wouldn't bother changing them. If they are different, then I would change them. I'd personally say no to SS lines and just go OEM!
