Eibach Pro Kit - ALIGNMENT DONE - RESULTS
Old Jul 10, 2009 | 02:17 PM
DanMardik's Avatar
DanMardik
Took this with my camera..
Let me know what you all think of the before and after. Doesn't really seem there had to be much adjustment made.
Old Jul 10, 2009 | 03:15 PM
oOmikeyboy's Avatar
oOmikeyboy
It looks like all they adjusted was the front toe and rear toe.
Old Jul 10, 2009 | 07:27 PM
amoney805's Avatar
amoney805
is this before or after the springs settled?
Old Jul 10, 2009 | 09:09 PM
DanMardik's Avatar
DanMardik
This is after the settling of the springs.
Old Jul 13, 2009 | 03:46 AM
DanMardik's Avatar
DanMardik
Any input guys?
Old Jul 13, 2009 | 04:10 AM
STOOF's Avatar
STOOF
well the most important thing is the toe, thats what'll chew up your tires unevenly, so since they got that back in spec you should be fine with those settings.
Old Jul 13, 2009 | 08:46 AM
philter25's Avatar
philter25
not bad. truthfully, i put eibach's on and the car has settled, but im not even going to get an alignment. i think the stock wheels are pretty poor and have been showing a lot of wear. id be suprised if i get 15-20k miles on them so i think next year i'll end up buying new wheels and getting an alignment then when i get my wheels mounted and balanced. eibach's barely put the car out of spec.
Old Jul 13, 2009 | 12:20 PM
Taktix1's Avatar
Taktix1
did any of you guys get a camber kit?
Old Jul 13, 2009 | 12:31 PM
philter25's Avatar
philter25
I didnt because it only barely puts the front camber out of spec.
Old Jul 19, 2009 | 11:19 PM
davv1215's Avatar
davv1215
Here are mine:
LF Camber - Before and After = -1.6
RF Camber - Before and After = -1.7
LR Camber - Before and After = -2.0
RR Camber - Before and After = -1.8
LF Caster - Before and After = 5.2
RF Caster - Before and After = 5.5
LF Toe - Before / After = -0.16 / 0.03
RF Toe - Before / After = 0.09 / 0.06
LR Toe - Before / After = 0.15 / 0.13
RR Toe - Before / After = 0.11 / 0.12
Any thoughts (am I going to see any negatives with these numbers)?
Old Jul 19, 2009 | 11:58 PM
Blackjack's Avatar
Blackjack
Alignment looks fine! You should be set. Even though they didn't touch much, even the slightest bit of adjustment can save you thousands of miles on tires.
OneSickBlackG
Jan 6, 2016 08:49 AM
TheIvoryG
Sep 23, 2015 02:06 AM
EnYcee-G
Sep 3, 2015 04:35 PM
Andyg90
Sep 2, 2015 06:10 PM
