I rub on H techs with 20's
Old Apr 30, 2008 | 07:40 PM
  #31
broodie's Avatar
broodie
Originally Posted by 06mtg35
I have 285/30/20 and i don't rub. most def offset problem!!
not even on bumps? how can it be offset problems when the wheels were custom built?
Old Apr 30, 2008 | 08:54 PM
  #32
Blackjack's Avatar
Blackjack
thats low..... HOE!!!!
Lol... You gotta take some to give some!
Old Apr 30, 2008 | 09:53 PM
  #33
sharif@forged's Avatar
sharif@forged
what offset are those rears. Probably a little on the aggressive side, is my guess. Try trimming the inner fender guard, if its just lightly rubbing.
Old May 1, 2008 | 07:58 AM
  #34
NJlakeshoreG's Avatar
NJlakeshoreG
you need to run a lil neg camber..not much but jsut a little...maybe go off a half degree and that should do it...or not even...im running i believe 1 degree of negative camber or 1.5 degree and im using 285-25-20 on a 10.5" in back and i dont rub n e where at all..and mine is lower..im using s-techs...
Old May 18, 2008 | 02:57 AM
  #35
johng35m's Avatar
johng35m
wow you are on s-techs too. i am rubbing on h-techs and i have 20's. i have 285/30/20 on the rear. i shaved the metal bracket but still rubbing when i hit dips. im thinking about going down to 275's
Old May 18, 2008 | 03:57 PM
  #36
broodie's Avatar
broodie
how do i run negative camber?
Old May 19, 2008 | 10:56 PM
  #37
sharif@forged
What tire brand and model are you running the rear? With the H tech's and Toyo T1R in that size, we are able to get it rub free....with a couple of sessions of grinding, and then test driving. It's doable with the T1R, but other tires can have thicker and blocker tread. Unfortunately, there is no perfect industry standard, as to what defines a 285/30/20.
Old May 19, 2008 | 10:59 PM
  #38
Blackjack's Avatar
Blackjack
John is running 20X10 in the rear with the 285/30-20. I'm sure the sidewall is a bit higher than mine since I would be a tad more stretched on the 20X10.5 so maybe that's the difference.
Old May 20, 2008 | 11:52 AM
  #39
Protein Shakes's Avatar
Protein Shakes
+1 one for the T1Rs. Good tires if you need a stretch. I just got myself a set and clearly see the difference on the sidewalls with the wheels mounted.
Old May 20, 2008 | 12:20 PM
  #40
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
Toyo = FTW !!!
Old Jun 4, 2008 | 08:24 PM
  #41
broodie's Avatar
broodie
still rubbing
i still rub even with trimming the fabric lining help please!!!!!
Old Jun 4, 2008 | 08:25 PM
  #42
Blackjack's Avatar
Blackjack
Did you trim the bracket too? Let me know. My car is the one that Sharif was referring to.
Old Jun 4, 2008 | 08:38 PM
  #43
jedmonds's Avatar
jedmonds
I had to trim my bracket too.
Old Jun 4, 2008 | 09:58 PM
  #44
sharif@forged
broodie, if you are still rubbing, then you definately have an offset or tire sizing problem. There is no much you can do about, other than raise your car up, or run a narrower tire, or a shorter sidewall. As mentioned, dialing in more negative camber can help as well.
Old Jun 11, 2008 | 01:18 AM
  #45
broodie's Avatar
broodie
what bracket? the one that holds the fender and bumper together? if yes then no i didnt trim that...what did u guys use to trim it?
