Are you happy with choosing Tanabe springs
Old Apr 6, 2008 | 06:23 PM
  #31
TerribleONE453's Avatar
TerribleONE453
JKS said he was gonna post some... idk??
Old Apr 6, 2008 | 08:35 PM
  #32
mako159's Avatar
mako159
Give me 10 mins.. Sorry, I gotcha
Old Apr 6, 2008 | 09:12 PM
  #33
mako159's Avatar
mako159
Heres the pics..
Attachment 78032
Attachment 78034
Attachment 78035
Attachment 78036
  #34
mako159's Avatar
mako159
Couple More
Attachment 78037
Attachment 78038
Old Apr 6, 2008 | 09:16 PM
  #35
mako159's Avatar
mako159
I'll try to get some better ones tomorrow outside.. Its dark now, didn't think it be any helpful if you couldn't see it good..
Old Apr 6, 2008 | 09:40 PM
  #36
Blackjack's Avatar
Blackjack
I can't really see any drop with the Tanabe's.
Old Apr 7, 2008 | 12:24 AM
  #37
gmlee86's Avatar
gmlee86
Once they settle, you'll notice it more. Here's some pics of mine that CandlestickPark from Driver took on Thursday at the mini 562 meet before rolling to Ricky & Ronnie's
Old Apr 7, 2008 | 04:00 PM
  #38
mako159's Avatar
mako159
Its not really a big drop like the H&R's, I got pics when I had them and pics of these tanabe's.. Theres a slight difference, but I just can't see going though all the hassle with alignment kits just to have your shocks blowing out every 6 months.. I mean you'll end up spending 200 for the rear alignment kit and 6-700 for the front upper arms (whenever they come out), just to put 2-300 dollars springs on the car; that still have a stiff ride.. Just my opinion..
Old Apr 7, 2008 | 10:38 PM
  #39
G35_Diva's Avatar
G35_Diva
Mako: Are there any cons expected to happen with the Tanabe's? Meaning, even with the subtle drop are they gonna cause things to wear out sooner than without? The front wheel gap does bother me, but I'm still trying to determine if Tanabe springs will cause more trouble than they are worth. I.E... excessive tirewear, shocks, etc.
Maybe it's still too soon to really know about the Tanabe's.
BTW: How much did it cost to install them??
Old Apr 7, 2008 | 10:52 PM
  #40
TerribleONE453
the more subtle the drop you will have less problems with tire wear and shock problems
Old Apr 8, 2008 | 07:25 AM
  #41
mako159's Avatar
mako159
G35 Diva, with the tanabe drop you shouldn't see any excessive wear.. As long as you get an alignment after the car is lowered, you'll be fine.. I had the H&R's and them springs will def tear your shocks and tires up, just because its so close to bottoming out the shock.. The camber created from the H&R's require you to get a camber kit for the front and rear. Which the front camber kit isn't even out of production yet.. Basically making it impossible to get the front aligned.. I called H&R and they just had nothing to say, I asked about alignment issues, and they recommended a camber kit, so I asked if they knew anyone who manufactured a front kit, and they were like ???? I installed both sets of springs myself..
Old Apr 8, 2008 | 11:42 AM
  #42
KAHBOOM's Avatar
KAHBOOM
Super Moderator of Pwnage
the Tanabe drop looks good. Just subtle enough to keep an OEM look while minimizing the wheel gap. tanabe FTW.
To those more expereinced with suspension mods- Am I correct in sying that coilovers help prolong shock life once you change to lowering springs?
Old Apr 8, 2008 | 12:22 PM
  #43
DetroitG37Joe's Avatar
DetroitG37Joe
Originally Posted by TerribleONE453
its just going to make the tanabe look like stock
i an tell the difference between the tanabe nf210's and stock..the tanabes give the drop that SHOULD have came out of the dealer...that kinda stock look im down with!!!
im gettin the tanabes. hopefully this summer!!!!!!!!!
Old Apr 8, 2008 | 01:10 PM
  #44
TerribleONE453
the car really should have came as low as the H-techs... tanabe still has to much front wheel gap for me.. thats all
Old Apr 8, 2008 | 01:26 PM
  #45
Kidcane's Avatar
Kidcane
Florida G Club
Im not feeling the Tanubes. I cant event tell they are on from the pics. Maybe if they stiffen the ride a bit but does not seem worth it otherwise.
You are kinda correct. Coils will have a very long life cause the strut is designed for the different coil settings and travel distance. Normally if you changed the springs you would want to change the strut as well so they work properly together. Basically coilovers are a spring/strut combo already matched.
