LED turn signals
Old Jul 27, 2024 | 02:29 PM
mad.cool's Avatar
mad.cool
LED turn signals
Had anyone successfully installed LED turn signals for the coupe, specifically in the rear? I know a common mod is to use the tail lights as turn signal but I’m not a fan of the look, I’d rather have LED’s in the original turn signal housing.
I recently purchased a set of LED 7443 bulbs for front and rear from LASFIT (T3-7443A/R) and while the front worked fine (I did have to get the polarity right however), the rears wouldn’t flash/emit properly. I’m getting a replacement set of rears from the vendor in case the first pair were bad. For reference, both pairs have circuitry for preventing hyperflash, and I can confirm that aspect works for the fronts.
Old Jul 28, 2024 | 04:14 PM
mad.cool's Avatar
mad.cool
Update: I received and installed the replacement rear turn signal LED's and they worked as expected, bright red and no hyper flash.
As a plug and play upgrade I'd recommend these, LASFIT customer support was excellent in shipping out the replacement and I didn't even have to send the first pair back. I purchased them from their website directly for about $48 each pair after a discount code. I didn't realize it at the time but they are also available on Amazon for $44. Personally I think this is a better option than the tail as turn mod from diode dynamics as you get LED turn signals front and rear for only 8 bucks more. If you were looking to be even more unique, I imagine you could install the amber turn signals in the rear. I contemplated this but ultimately went with red to keep the OEM+ vibe going.
Here is a quick video with hazards on.
cribbj
Mar 20, 2019 08:36 PM
presidentsdad
Feb 1, 2018 02:24 PM
xnick101
Dec 8, 2016 06:31 PM
ActionAl
Jun 7, 2010 11:00 AM
Xcalibur
13
Oct 6, 2009 09:39 PM
