Help What is this part called?
They are air guides or air deflectors. They redirect air from going to the tire as the tire is a high turbulent zone, it provides better aero dynamics lowering drag coefficient.
not sure rear part number but front right and left
https://www.discountoeminfinitiparts...k60a-80350.htm
https://www.discountoeminfinitiparts...k60a-80348.htm
From what I can tell/see in the pic it looks perfectly fine and normal.
unless its noticeable damaged/ripped or missing the pop clips then it should be fine.
it sits in front of the wheel blocking air that is under the vehicle on the sides from going to the wheel, instead it redirects the air to the center of the undercarriage.
