Help Both Lowbeams Suddenly Stopped Working
Old Jan 17, 2022 | 03:58 PM
ILM-NC G37S's Avatar
ILM-NC G37S
Out of curiosity, what happens when you pull and hold the light switch/stalk (aka, "flash to pass")? And/or activate the "panic alarm" using the fob?
Old Jan 17, 2022 | 04:09 PM
Rag7's Avatar
Rag7
Flash to pass works exactly as intended with the high beams. Panic alarm triggers the high beams as the horn goes off. Nothing from low beams.
Old Jan 17, 2022 | 04:14 PM
ILM-NC G37S
In other words the headlamps light up? Keep in mind there is only one bulb for the headlamps, not 2. There is a diverter within the lens that changes the angle of the beam.
Old Jan 17, 2022 | 04:30 PM
Rag7's Avatar
Rag7
High beams off
High beams on
Forgot to mention that I have aftermarket headlights, the headlight and low beam bulbs are separate. Low beams are 6000k bulbs and when on they come from the projector lenses in the corner. I believe the diverter situation is if you have the package for road following HIDs which I do not have.
Old Jan 17, 2022 | 04:36 PM
ILM-NC G37S
Well, damn it man, you should have said this from the beginning.... ​​​​​​
You are on your own then. Based on the readings from the multimeter, the car-side of the equation is doing exactly what it was designed to do. With regards to that aftermarket stuff, while the operating principles are the same, I/we have no way of knowing how they're setup. Might need to contact the vendor?
For the record, ALL G37's have bi-xenon headlamps whereas one bulb provides the light with a diverter on the lens to direct low or hi beams. AFS refers to a (optional) system where motors moved the lenses left or right according to steering wheel rotation.
Good luck...
Old Jan 17, 2022 | 04:41 PM
Rag7's Avatar
Rag7
Good luck...
Haha yeah I definitely should've brought it up earlier. The aftermarkets are using the OEM ballasts pulled straight from the original headlights, they've been running perfectly for about 2 years up until now. So essentially the way that the low beam bulbs are being powered is identical to how it was with the OEM headlights which is why I believe it to be unrelated to the aftermarket headlights.
Old Jan 17, 2022 | 04:42 PM
Rag7's Avatar
Rag7
I've been using these aftermarkets without issue for 2 years on the OEM ballasts*
Old Jan 17, 2022 | 04:51 PM
ILM-NC G37S
Easiest test: run a jumper from the battery to the ballast... If it works, the issue is within the IPDM/er. If it doesn't, then it's either the ballast, ignitor, or bulb.
Being both sides are out, my bet would be a issue upstream (IPDM, switch, etc.).
Old Jan 17, 2022 | 08:15 PM
Rag7's Avatar
Rag7
I went out and bought some jumper cables, forgive me for inexperience but how would one go about connecting the cables to the ballast? Do I somehow hook them into the plug where the connector usually goes or another part?
Old Jan 17, 2022 | 09:14 PM
ILM-NC G37S
I hope you did not go out and buy a pair of battery jumper cables!!! They would be too large for this test. A pair of wires and some alligator clips would be perfect. That said, here is a brief tutorial on "bench testing" the HID ballast / bulb assembly.
You MUST completely remove the vehicle harness connector from the headlamp and move it out of the way (make sure the ballast is plugged in). From there:
you will clip the POSITIVE jumper wire to pin #5, then you will touch the NEGATIVE jumper wire to pin #3. If all is good the bulb should fire right up.
PERFORMING THIS TEST IS AT YOUR OWN RISK. PAY CAREFUL ATTENTION TO NOT TOUCH ANY OTHER PART OF THE VEHICLE WITH THE JUMPER WIRES!!! I WILL NOT BE RESPONSIBLE FOR ANY DAMAGES. IF YOU ARE UNSURE OR HAVE DOUBTS ABOUT DOING THIS TEST, DON'T!!!!!
Old Jan 17, 2022 | 09:23 PM
Rag7's Avatar
Rag7
You MUST completely remove the vehicle harness connector from the headlamp and move it out of the way. From there:
PERFORMING THIS TEST IS AT YOUR OWN RISK. PAY CAREFUL ATTENTION TO NOT TOUCH ANY OTHER PART OF THE VEHICLE WITH THE JUMPER WIRES!!! I WILL NOT BE RESPONSIBLE FOR ANY DAMAGES. IF YOU ARE UNSURE ABOUT DOING THIS TEST, DON'T!!!!!
Got the wrong cables haha. Anyways, as I was taking the ballast out of the headlight, just found out that water got into this ballast somehow including the connector for the ignitor so I'm 90% sure the issue is the ballast assembly now.
Old Jan 17, 2022 | 09:26 PM
ILM-NC G37S
Well, as we all know: water and electronics do not mix at all...
At least you are narrowing down the issue and should be in good position to repair the problem!
Please update this thread when you get it resolved.
Old Jan 18, 2022 | 12:19 AM
Rag7's Avatar
Rag7
Problem has been solved. I took apart the ballasts and blow dried them to get rid of all water residue and put them back in. Low beams work perfectly now!
Old Jan 18, 2022 | 09:30 AM
  #29
ILM-NC G37S
We're both sides wet or just one?
Glad it was a simple, and inexpensive, repair!
Old Jan 18, 2022 | 12:45 PM
  #30
Rag7's Avatar
Rag7
Both sides were wet, passenger side more so. I'm honestly surprised they still work. Something interesting to note is before I took apart the ballasts, I unplugged one with the headlights on and checked the connector that goes to the ballast with a multimeter. It was getting 0 power. Seems like the car was intentionally cutting power off from the ballasts. Once I got them all back together without water, they began working.
