2011 Coupe Trim Part #'s
Old May 2, 2020 | 08:15 PM
Alto101's Avatar
Alto101
My 2011 coupe was purchased used a few years ago in great shape except for the driver side trim pieces (likely from the seat belt hitting it). Anyone have the part #'s available? I need both the piece that is horizontal below the door handle and that goes up diagonally near the window switches.
Thanks!
Old May 2, 2020 | 09:00 PM
ILM-NC G37S's Avatar
ILM-NC G37S
Do you have the dull gray (Shodo) trim or the wood? Assuming you do NOT have wood trim and do NOT have a IPL, here is what I found for a 2011 Coupe:
If you order these trim pieces new be warned: they are not cheap. I remember from when I upgraded my '08 (Washi) interior to '14 (Obi Silk) the trim was expensive. The trim will run:
80944 and 80945: ≈$100.00 each;
80920 and 80921: ≈$160.00 each.
Because of the crazy prices- and the fact these pieces are easily scratched- many folks decide to vinyl wrap those pieces. I do not have the patience for that but it is something to consider if you are on a budget. Typically discountinfinitiparts.com has the best prices should you decide to buy new but as always, shop around. If you do buy new, be sure to verify the part numbers using your VIN.
Hope some of this helps.
Old May 3, 2020 | 10:35 AM
Alto101's Avatar
Alto101
On Discountinfinitiparts.com. the 80944 is labeled right door and 80945 is labeled left door. Do you think the diagram above is incorrect? Part #80921 is labeled as left so the diagram matches for that part.
I don't have the wood trim or IPL.
Thank you for your help
Old May 3, 2020 | 11:48 AM
ILM-NC G37S
Good catch. I edited the image to fix the error.
mwvolkma
May 3, 2020 12:59 AM
blkceaser
Jan 24, 2018 10:13 AM
jee-sedan
Nov 10, 2015 06:35 PM
jazzmang
May 20, 2014 10:50 AM
dopetime
Jan 5, 2012 09:28 PM
