I’m doing it! Black Headliner, Cracked Dash Solution and no more Vibrations
Old Sep 27, 2021 | 11:14 AM
  #376
sobeIPL's Avatar
sobeIPL
🔥🔥Pics🔥🔥
Old Sep 27, 2021 | 03:46 PM
  #377
BULL's Avatar
BULL
Moderador
Amazing shots!
Old Sep 27, 2021 | 05:41 PM
  #378
sobeIPL's Avatar
sobeIPL
Originally Posted by BULL
Amazing shots!
it’s the car, not the shots 😎
Old Sep 28, 2021 | 08:17 AM
  #379
BULL's Avatar
BULL
Moderador
75% the car because look at the rest of the shop, looks amazing
Old Sep 28, 2021 | 12:07 PM
  #380
iCrap's Avatar
iCrap
Looks like a brand new car! looks amazing.
Old Sep 28, 2021 | 04:16 PM
  #381
sobeIPL's Avatar
sobeIPL
Thanks A brand new car may have been more economical to be honest. Dropped a ton of money in this thing, probably too much but hopefully she’ll treat me well now. I’m almost scared to drive it 😬
Old Nov 9, 2021 | 12:31 AM
  #382
peterpj's Avatar
peterpj
@sobeIPL, did you have any issues with the airbag light on the dash coming on after installing the GTR seat belts?
Old Dec 6, 2021 | 04:09 PM
  #383
sobeIPL's Avatar
sobeIPL
No, they are the exact same thing mechanically, same exact plug for the airbag.
the only difference between the G and GTR belt (besides color) is the plastic thing that extends out to keep the belt off your neck is a smidge smaller. It’s barely noticeable and GTR version is a little better imo.
Lastly, make sure you re-use the G bracket that the top part bolts up to. (My belts came with those brackets attached but that shouldn’t be the norm). The GTR bracket has a slightly different angle and it won’t work.
Old Dec 8, 2021 | 11:19 AM
  #384
petemo94's Avatar
petemo94
Somethings missing but I can’t put my finger on it🤔
I must have missed it, but why was the subframe dropped? What happened?
Old Dec 8, 2021 | 11:40 AM
  #385
sobeIPL's Avatar
sobeIPL
@petemo94 I lived right on the water in south beach (hence my username) and had some issues with rust. The body shop handled a majority of the issues that are body related but I still had a lot of rust underneath. Luckily for the car I moved and now she’s a garage queen far away from the salt water.
Old Dec 8, 2021 | 11:50 AM
  #386
petemo94's Avatar
petemo94
Ah - I see. Beautiful car you got there. Can't imagine how good the car must smell with all of that leather! She's earned the title of "Garage queen" based on what you've done to it. Wished you did some sound measurements before and after all of these improvements.
Here's my experiment I did a while ago. Would be curious to see what you are getting at this point as a way to compare.
https://www.myg37.com/forums/d-i-y-i...h-results.html
Old Dec 8, 2021 | 03:44 PM
  #387
sobeIPL's Avatar
sobeIPL
@petemo94 Thanks man. Yea the car smells amazing. I’ve searched this forum ad nauseam and have never seen your thread! I actually bought a few cans of boom mat to do the fender area but never got around to it. Someday…
Is the 4-5 DB you drop actually noticeable? I didn’t measure b/ I don’t have a decibel meter and just didn’t think too. I guess I could measure in the future and you could compare it to your base results…
While I think my results are definitely noticeable, my car does ride quiet and heavy feeling like a real luxury car, I don’t think it’s worth the time and money to do what I did as far as the full MLV treatment. I would instead just spot treat problem areas with CLD. The leather wrapping is well worth it though. Looks great and was much less work than the sound deadening.
Old Dec 8, 2021 | 03:59 PM
  #388
petemo94's Avatar
petemo94
So you can download an App (for the iphone I used the dB Volume app) and let your phone be the microphone. Is it accurate? Probably not, but I would like to see what you register as the dB compared to my changes and the speeds I noted. Apples to apples comparison.
I definitely did notice an improvement. However, slowly over time that difference fades away. But I felt that my exercise was worth it and I'm sure yours was DEFINITELY worth it. Amazing detail you provided us. Makes me want to put sound deadening in my transmission well now!
My "AFTER" tests:
  • Local Road @ 55MPH - Range = 64dB - 66dB (~1dB gain)
  • Local Street @ 25MPH - Range = 62dB - 65dB (~2-4dB gain)
  • Highway @ 70MPH - Range = 66dB - 71dB (~2-3dB gain)
Old May 25, 2022 | 02:01 PM
  #389
sobeIPL's Avatar
sobeIPL
@ILM-NC G37S can you please let me know which wires I should tap? Looking for a set of wires that go up to my speakers door speakers. unsure which of these are signals from radio versus which go the speakers. I am replacing the Bose amp and speakers but need to reuse the one set of speaker wire that will go to my crossovers. Thx
Old May 25, 2022 | 04:43 PM
  #390
ILM-NC G37S's Avatar
ILM-NC G37S
Welcome Back, Kotter, errr... @sobeIPL
All of your speaker signal outputs (for the front doors) are on the B42 connector. From the 2013 Coupe FSM:
Driver Door:
Squawker & Tweeter feed off pins:
1 (signal +)
2 (signal -)
Woofer feeds off:
9 (signal +)
14 (signal -)
Passenger Door:
4 (signal +)
3 (signal -)
Woofer feeds off:
5 (signal +)
6 (signal -)
Is this what you are needing confirmation on or did I misunderstand?
